ABS obd1 reader on Volvo 850 1994. Constant light, no code. Topic is solved
Evolvo850B
Year and Model: 850 GL 1994
Post by Evolvo850B »
Volvo 850 1994
Hi! I have a problem with the obd1 reader on my Volvo 850 1994.
I first tried and got a bunch of codes on the ABS. Then I would clear them and then it stopped giving me anything at all.
I also tried replacing the ABS module. but still the same problem.
Would like to see the fault codes on the ABS. But as soon as I put the plug in A3 the light comes on a little.
When I press the button the light comes on but nothing happens, no 1-1-1 or anything.
When I test other sockets for example A2 I get 1-1-1
But the socket for ABS gives nothing but lights up when I press it, and as soon as the pin is in the socket it lights up a little… any tips? :(
aeg
Year and Model: 97 850GLT
Been thanked: 32 times
Post by aeg »
Check the ABS fuse?
Evolvo850B
Yes, checked all fuses. Removed the battery over the night. Have seen people having this problem before but no solution..
Evolvo850B
I thought I would do everyone who has this problem in the future a favor and write the solution I never found online :)
What worked for me was that when the car was on and the cable was in the A3, I pulled out the fuse for the abs module. Then I put it back in. The module clicked and the constant light went out. Then I could see the codes and clear them.
wizechatmgr
Has thanked: 45 times
Been thanked: 126 times
Post by wizechatmgr »
Guessing this was a 3rd party scan tool - not a real volvo scan tool?
If so, I've encountered this before with my Maxidas *Autel* scan tool before.
Evolvo850B
wizechatmgr wrote: 02 Dec 2025, 00:33 Guessing this was a 3rd party scan tool - not a real volvo scan tool?
This was the built in OBD1 on 850s before 1995. No obd2
