94' Volvo 850 OBD1 A3 ABS & B1 Climate Control Port Codes
Baptiste1106
Year and Model: 850 1994
Been thanked: 2 times
Post by Baptiste1106 »
Read my OBD1 port and got
B1 Climate Control. I replaced a brand new blower fan and nothing when i move slider.
122 Outside temperature sensor open circuit or shorted to 12 volts
411 Blower fan seized or drawing excessive current
414 Driver’s side interior temperature sensor inlet fan seized
418 No control signal to blower fan power stage
A3 ABS (abs light on dash). Can't find the definitions for all the others. What a summer i enjoyed w/o A/C :cry:
312
213
214
141
142
144
122 Right front wheel sensor
Year and Model: Many Volvos
Been thanked: 75 times
Post by Ozark Lee »
Clear all of the codes and see what comes back. The biggie is port B-1, code 4-1-8. That is normally indicative that the power stage (blower resistor) is bad. Code 4-1-1 is a precursor to code 4-1-8 in most cases since the MOSFET in the power stage can only deal with a limited current sink amperage before it either opens or shorts out.
The 1-2-2 and the 4-1-4 won't cause the AC to not work, it just may not make great decisions in the AUT mode.
Baptiste1106
@ Ozark Lee... Whats AUT mode ? I cleared the ABS codes and the codes in the post is what come back. Any suggestion on the ABS ? What to replace, what to check, how to check ? Thanks again
Post by Ozark Lee »
The AUT mode is the automatic mode on the center switch and the blower switch. It puts the system into auto pilot and it varies fan speed and directs air flow how it thinks it should be done. I rarely use it since I prefer to direct the air where I want it to go rather than where the computer in the ECC thinks it should go.
You have nearly every ABS code in the book and I doubt that they are all still valid errors. The ABS unit stores all codes that it has ever had until they are cleared manually. If you clear them and see what comes back after you drive the car it should narrow things down to one or two things that need attention.
esl_97_850_T5
Year and Model: 1998 S70 GLT
Has thanked: 18 times
Been thanked: 27 times
Post by esl_97_850_T5 »
Baptiste1106
The ABS codes are presumably the same as can be found in the ABS/TRACS DTCs TABLE in "anti lock brake system and traction control.pdf" in the 1995 Volvo 850 .zip download.
esl_97_850_T5
1998 Volvo S70 GLT - 205.5K miles - S70 & M44 testbed in 2016-2019; traded 2019-07-15 (for spare time)
1997 Volvo 854 T5 - 147K miles - 850 testbed in 2012-2017; junked 2017-09
