Solved the mystery of no low coolant light , bulb tested good.
This is a really bad idea, kids
1999 s70 awd no heat [low coolant] 9144221 [map of ECC damper positions] Topic is solved
- Has thanked: 1497 times
- Been thanked: 3810 times
Re: 1999 s70 awd no heat [low coolant] [map of ECC damper positions]
- Has thanked: 2650 times
- Been thanked: 1240 times
oof
This is on Karla Kat, a 1999 s70 AWD
She is a capital auction special, I drove her home from DC in blissful ignorance like this.
The coolant level bulb is self tested by the DDM on a 1999, so I knew the bulb was good. Silly me for not checking for a bypassed warning system.
Evita is a 2018 rescue from NJ, a very cool lawyer chemist I still talk to regularly
Juno is a December 2025 rescue from ARF Hampton’s who talks every morning.
Polished this one off with a new level sensor from FCP
Wrapping up this.
I measured the dead volume of the heater core 9144221 as 300 ml +- 50ml
This does not include any pipe volume. Temperature 22c, P= 1012 torr, Jupiter aligned with Mars.
