Question on Blower/Resistor
- Has thanked: 1497 times
- Been thanked: 3809 times
Re: Question on Blower/Resistor
Ii bite on this one. I’m guessing running backwards runs on the high ridge on worn brushes which will work for a short time, then will fail again. Time for a new motor
- Grantkat
- Year and Model: 1999 s70 GLT
- Has thanked: 47 times
- Been thanked: 43 times
You are correct - I removed the mounting cover. The motor housing has a decent amount of dust as a result of brush wear.
Part is on order...
Part is on order...
1999 S70 GLT ~193k
2014D VIDA/DICE
2007 Jeep Wrangler Unlimited ~ 315K
2008 Lincoln MKX ~130k
2008 Toyota Sequoia ~ 252k
Powered by coffee, stripped bolts, and questionable decisions.
2014D VIDA/DICE
