S70 - Bad floor vibrations in cold Topic is solved
Mark345
Post by Mark345 »
I have a 2000 S70 and have had some really bad vibrations in the floor and steering wheel while accelerating. It only does it when the car is cold, and slowly subsides as the car is warming up. Every single motor mount has been replaced on this car - so what else could it be? Strut housings? Lower control arm rubber bushings? I have no idea where to begin.
matthew1
Site Admin
Year and Model: 850 T5, 1997
Has thanked: 2660 times
Been thanked: 1253 times
Post by matthew1 »
Weird that it goes away. I want to say wheel imbalance...
What about a spark plug wire that doesn't make good contact until the engine is warm? A nonfunctioning cylinder would certainly cause a whole lot of shaking. How's the power when it's cold?
Also -> Amazon link
Tsquared
Year and Model: 11 C30
Post by Tsquared »
Replace the plugs after you crank it when cold and let it run for about 5 minutes. If it were a fouling plug it would be evident which one it was. If new plugs didn't fix it I would then replace the wire to that cylinder, then the cap...
Good luck
'11 C30 T5
'96 854 - died an early death with 184K miles. Killed by the front end of an LTD on a suicide mission (T-boned and both cars totaled).
