when locking 1998 v70 with remote, the alarm goes off after around 5 minutes. took it back to garage, they cant find anything wrong, clearly there is a fault. does anyone have a solution, other than locking it with the key?
also, where is the alarm, i thought about disconnecting it but cant find it anywhere?
v70 alarm, help. Topic is solved
Guest
it should be located behind the right headlamp.... if You disconnet it You will not be able to start the engine!
if You want, send me Your e-mail address at [email protected] and I will send you alarm sheme, so You can try to fix it.
regards....
regards....
- 677 Views
Last post by Ozark Lee
- 3489 Views
Last post by ZootAllures
