Resurrecting the wife's 99 T5
Fixing Up 99 S70 T5
Auburn T5
- Year and Model: 1999 S70 T5
- Been thanked: 2 times
Re: Resurrecting the wife's 99 T5
yeah and it's not an OBDII code either I don't think (at least it doesn't show up on my scanner). Isn't the dealer the only one that can scan for that code?
2020 - Tesla Model 3 Performance
2020 - XC60 T5
1999 S70 T5 - Bilstein touring shocks/struts, B&G S2 springs, OBX full exhaust, other misc. stuff
2020 - XC60 T5
mecheng
- Has thanked: 15 times
- Been thanked: 21 times
Only the dealer can read these codes correct? I have no codes showing. I will try cleaning the temp sensor like some have suggested. Both my A/C and heat work perfectly.abscate wrote:The flashing lights indicate a fault in the climate system. It can be benign or it might be inhibiting your AC completely - you have to read the codes to learn this.
1997 Volvo 850 GLT - 190km
Boost is my drug of choice
- Year and Model: Many Volvos
- Been thanked: 75 times
I think VOL-FCR will read climate codes on the S/V series. Cracked versions of the program are all over the P2P sites and the VAG-COM cable is under $20.00 on eBay. For the 850s you need to build a flash code reader.
Auburn T5
So I need this cable
http://www.ebay.com/itm/KKL-409-1-vag-4 ... 1e8c0e68e1
And I need to "acquire" the VOL-FCR software?
2020 - XC60 T5
2020 - XC60 T5
mecheng
Put a vacuum to the temp sensor to clean out all the dust and it worked! No more blinking lights.
It appears to be a fan I guess to suck air past the probe? Funny thing is it only spins when it's not on auto, I thought it would be the other way around???
chashiubow
- Year and Model: 850 turbo wagon x2
Thanks for the update.
2005 XC90
That is the cable I have. The VOL-FCR program is written for a RS-232 Com port so you will need to set up the USB to emulate a com port (Com 1). On Windows 7 that is easy but it was a bit more of a struggle on my old XP laptop and I had to search for drivers to make that happen.Auburn T5 wrote:So I need this cable
Auburn T5
Bump for an update. Couple new parts going in although the manifold will have to wait for a couple of other parts first
I'm getting the manifold ceramic coated but I'm wondering if I should port the main outlet that connects to the turbo?
2020 - XC60 T5
2020 - XC60 T5
Auburn T5
Good question. Not really sure to be honest. All I know is that I have an exhaust gasket that's falling apart resulting in an exhaust leak that I'm going to replace with the stainless ARD gasket
http://www.ardideas.com/Exhaust-manifol ... p_311.html
And if I'm going to be pulling the stock manifold off, for the low cost of an R manifold, I would like to put that back on instead of the factory one.
2020 - XC60 T5
2020 - XC60 T5
