I am looking for suggestion for new brake pads. I have tried 3 brands and the squeel goes away for a little while but comes back within 6k mi or so.
I don't know what the first brand was as they were on it when I bought the car. So I bought OEM Volvo they were the worst, I have Wagner Thermo Quiet pads on now and they did great for a year but about a month ago the rear started to squeel. At first only when I backed up and only the first time but now it is getting worse.
Brake Pads that don't squeal
- Year and Model: Many Volvos
- Been thanked: 75 times
I am surprised that you had issues with the OEM pads. They are filthy dirty but they are normally quiet.
Is the noise from the front or the rear?
If it is the rears did you use the shims and grease them?
There are a couple of versions of the rear calipers. One version has a step built into the end of the piston and the other has a flat faced piston. On the step faced piston you can use a full shim, on the flat faced piston you should use a "trimmed" half shim.
I have also used a product called "Disc Brake Quiet" from Permatex when I didn't have any Sil Glyde brake grease and it has worked fine with the Mintex Red pads for over 2 years now.
Autozone sells there top of the line ceramic.It has a rubber backing to help keep it quiet.Great stopping power.Comes with new vibration clips.
1999 V70 XC
1999 V70 under constuction,or
destruction from previous owner
Mobil 1
K & N Filters
Ceramic brakes
Mobil 1
K & N Filters
Ceramic brakes
ANIGAV Inc.
- Year and Model: 96 850 t5
i thought i was to avoid ceramic and go with semi-metal to avoid squeal.
Mine shriek like a banshee and I'm in dire need of replacement. Cant remember which they ar though.
1996 - 850 turbo
- tom39
- Year and Model: 2011 S80
Thanks everyone
Lee, the OEM pads that squeeled were on the rear. The shim was a full shim (square w/a hole in the center). So I'm guessing flat piston. Not sure of the brand of grease used but they were greased, I had the parts guy get some from the mechanics in the Volvo shop and put some in a coffe cup for me when I got the pads, the grease was white thats all I know.
I also put in a new pin kit with each new pad set.
I still have the old pads. They look brand new.
I'm thinking of cleaning and scuffing them and putting them back in. Your right though they are dirty.
11 - S80 Silver 132k/mi
I've had no issues with the autozone ceramics.I also installed new rotors.
I've had the ceramics on my jeep grand cherokee any toyota 4runner no noise at all.
1999 V70 XC
Mobil 1
K & N Filters
Ceramic brakes
Mobil 1
K & N Filters
Ceramic brakes
C@lvin
- Year and Model:
- Been thanked: 2 times
I used a set of the Autozone ceramic (made by ....Morse I think) on the front of my Saab 9-5 with no squeal or squeak so far after about 5K miles. It took a bit to get them "seated" but after that I love them for braking and no dust.
Calvin
98 S70
00 V70
240,245,760,940,850 Turbo
98 S70
00 V70
- tom39
Ok well here is the update. Took the wagner thermo quiet pads out and took them back to the auto parts. They gave me a replacment set, much to my suprise.
I put the new set in without the shims and coated the back of the pad with CRC - Disc Brake Quiet. I seems to make a gummy coating on the back of the pad. Don't know if it will work but gave it a try anyway.
JRL
- Year and Model: Several
- Been thanked: 16 times
OEM Volvo pads do not squeal if mated to OEm rotors.
If so, the install was incorrect
- 11 Replies
- 5172 Views
Last post by jreed
- 460 Views
Last post by Fish stick88
