1999 S70 vs. California Emissions Test
This topic is in the MVS Volvo Repair Database » 1999 S70 vs. California Emissions Test
S70 Scott
Year and Model: 1999 S70
Volvo Repair Database 1999 S70 vs. California Emissions Test
Post by S70 Scott »
Hey, everyone. I'm pulling my hair out trying to get my 1999 S70 to pass the California smog test. Emissions aren't the problem. It's the stinking computer. Several months ago I disconnected the battery to clean the posts, and when I did that it reset all the computer monitors.
1500 miles later, three of the monitors -- the catalyst, evaporative, and oxygen sensor -- still aren't ready. I can have 2 "unready" monitors, but not 3.
My mechanic tells me the car isn't throwing any codes, so there's nothing to fix. I just need to keep driving it. Specifically, there's a 30-step drive cycle that will reset all the monitors (he gave me a copy), but it's been impossible to complete in Los Angeles traffic. Meanwhile, the DMV tells me that due to new legislation they can't extend my registration any more than 1 day and that the car is now illegal to drive.
So I'm not allowed to drive the car because it's not registered . . . but I have to keep driving it to get it registered :(
Faced with that, I took the car to the dealer this week and asked if I could pay them to complete the drive cycle. This morning, they called back to say they had to do the following before they could reset the monitors: replace the battery cables ($450), replace the main relay ($60), replace the evaporative valve ($90), and clean the throttle body ($220).
For those of you who know what all goes into resetting a monitor, does this sound plausible? Could these issues really being causing the monitors to remain unready? Seems odd, especially when the car isn't throwing any codes.
Thanks in advance.
jblackburn
Year and Model: 1998 S70 T5
Has thanked: 9 times
Been thanked: 19 times
Post by jblackburn »
Some of those may be things it needs, sure, but with the exception of the EVAP purge valve, none of them will keep it from achieving a 'ready' monitor. Again, there are no codes for that, so I would ask "why?"
$450 for battery cables is absolutely ridiculous.
'98 S70 T5
2016 Chevy Cruze Premier
JRL
Year and Model: Several
Been thanked: 16 times
Post by JRL »
Cables cost about $170 retail and they really are a good 2+ hours ro install
The B+ cable is a SOB to install
S70 Scott
Post by S70 Scott »
Speaking of the battery cables, is there any chance a voltage drop across the positive cables could cause the ECM memory to be erased . . . which would continually reset the monitors and never allow them to set?
Also, shouldn't this throw a code?
jimmy57
Been thanked: 320 times
Post by jimmy57 »
yes, you could be onto something there. The cable between + terminal and the relay/electrical box is a problem area too. Check V drop between + post and the stud with nut you'll see on inboard side of the relay/electrical box by master cylinder while cranking engine. Low voltage to ECM won't set a code reliably but can cause monitor status dump as well as fuel trim memory dump.
The common denominator of those items not completing is a completed driving trip. The Oxygen sensors aren't cleared until a constant part throttle drive at steady load for something like 12 minutes (the sheet you have probably has the exact time) and catalyst diagnostics aren't happening until ECM is happy with O2 sensors, Evaporative only ocurs when the others are good and then you pull up and idle engine for 3-4 minutes to assure time to complete the tank pressure testing.
The 96 -98 are the SOB's to get monitors to trigger on and the best way to hurry those is a drive at high load to get catalysts and O2 sensors burned clean from lots of town short tripping and then to drive the prescribed "trip". ANd then you let car set overnight and do it again the next day as two checks have to be complete for monitors to pass. That car could have one complete so one "trip" and a visit to the CARB check might do it. Surely a receipt if you got one, from the inspection station with a fail would make the constables happy for the out of registration thing.
850gltvlvownr
Year and Model: 850GLT 1997
Post by 850gltvlvownr »
Is this also true with 1997 850GLT? I replaced the engine coolant temperature sensor 3 months ago and erased code P0117. Also, a loose connector to the turbo wastegate solenoid threw a P0243 code. After fixing the connection and erasing the code, the check engine light no longer came on. There were no pending codes. However, the monitors have not run since. Where can I get the procedure to follow to make the monitors to run? By the way, I am using an Innova 3100 Code Reader.
Thank you in advance.
VCA
Been thanked: 5 times
Post by VCA »
The drive cycle for a 1999 S70 is (this is straight from VIDA):
Driving schedule:
  • Start the engine
    shift gear selector to drive
    accelerate gently to 1500–2000 rpm
    drive for 5 minutes at 1500–2000 rpm
    run the engine at idle speed for 70 seconds
    drive engaged, air conditioning (A/C) off
    drive for 6 minutes at 1500–2000 rpm
    run the engine at idle speed for 40 seconds
    drive engaged
    run the engine at idle speed for 50 seconds
    Engine brake from 4000 rpm to approximately 1300 rpm a few times.
Note! Do not use the accelerator pedal (AP) during engine braking.
2008 S80 T6 AWD
1999 S70 GLT
1998T5
Post by 1998T5 »
I have been going through this issue since January 2011. My 1998 S70 T5 would not pass smog either. First off, I had a check engine light that would come on and ,secondly, I had an issue with the computer stating it was not ready whenever the technician would plug it in and test it. The check engine light turned out to be a relay that a Volvo specialist replaced after trying to change a couple of valves in the emisions system. The valves may have been bad, but that didn't solve the check engine light until he replaced the relay. Still, even after all that the computer would not re-set because it will not check all parameters. Three or four of the parameters still come up as not ready even after all driving cycles have been completed. I even tried a replacement EMU without any luck. Luckily that did not cost me as much as I was quoted originally. It turns out that these model year Volvos (from around 96-99) have a glitch in the computer check/set system. These cars can be legally tested without checking the computer check/set system. The State of California will accept a passing test, however, you must find a smog technician that is aware of this issue with these Volvos. I finally just got my car to pass without any further work and without the computer being "ready" or reset. Some smog test and repair facilities are aware of this issue. Even the dealers are aware and can attempt to "repair" the glitch in the computer system. I was told only the dealer has the equipment to do this, but that it is a 50-50 shot that is successful. But since the state doesn't care if the computer says it is ready or not, then why waste time and money?? All of the above information is based on my experience with my Volvo and from information that was told to me by a very trusted Volvo specialist and a trusted smog test/repair/auto repair shop. These two shops/specialists treated me very well and helped me solve my long, drawn-out smog test problem. I hope that this will help others.
tjts1
Year and Model: 96 855 NA 5 speed
Been thanked: 4 times
Post by tjts1 »
BUMP
Here is some additional information from the EPA you can bring to the technician smoging your car if its running into readiness issues.
APPENDIX D
Manufacturers Known to Have OBD Readiness Issues
1996 Volvo 850 Turbo - Vehicles will clear readiness at key-off. There is no reprogramming
available for this line of vehicles. These vehicles should be scanned for MIL illumination
without regard to readiness status.
Volvo Technical Service Bulletin #SB 2-23-0056.
1996-98 Volvo vehicles (excluding 850 Turbo) - These vehicles may have a high degree of
“Not Ready”for catalyst and evaporative monitors due to a “trip based” design. Volvo has
provided driving cycles in its service information to allow monitors to operate. These
vehicles should be treated as other non-problematic vehicles.
http://www.epa.gov/OMS/regs/im/obd/r01015.pdf
Ambitious but rubbish
JRL
Post by JRL »
Someone had told me this info was around somewhere but this is the first time I ever read a copy of that..
Thanks
