Abs/brake light/no speedo. Had abs module rebuilt, no chang
2k2wranglerx
- Year and Model: 2000
Any ideas? I assumed it was the abs module. I sent it out to be repaired and no change. I bought this this way and the speedo worked before I sent the abs module out. I'm also getting the low voltage code and the dash light failure code.
2k2wranglerx
Oh it's a 2000 v70xc
- Year and Model: Many Volvos
- Been thanked: 76 times
Make sure that the large connector is actually seated properly. It is very easy to think that it is seated when it hasn't actually grabbed the pins that draw it down into the socket.
2k2wranglerx
Il double check that tomorrow. Makes sense since the speedo isn't working now.
It's still throwing the mil code which I think is a bulb on the dash out and p1633 which is stumping me.
2k2wranglerx
Oh wait 1633 is speed sensor... Might still be the abs module...
jblackburn
- Year and Model: 1998 S70 T5
- Has thanked: 9 times
- Been thanked: 20 times
That (probably) means that one or both of your front wheel sensors has a problem or the wiring is broken.
'98 S70 T5
2016 Chevy Cruze Premier
linkhart
- Year and Model: 855 GL NA Man '96
I had these symptoms and asked my dealer (Keystone). they suggested I try wiggling the key up and down in the lock. It worked. Eventually I ended up replacing the electrical connections on the lock and this fixed the problem. Apparently this is a known issue.
good luck.
good luck.
2k2wranglerx
woah what? i defintely have a loose connection in the column. when i was getting out of the thing last night i pushed on the wheel and the horn blew! lol. what connections did you replace? What lock? do you mean the ignition cylinder?linkhart wrote:I had these symptoms and asked my dealer (Keystone). they suggested I try wiggling the key up and down in the lock. It worked. Eventually I ended up replacing the electrical connections on the lock and this fixed the problem. Apparently this is a known issue.
good luck.
jblackburn
It would be the electrical portion of that ignition switch, which is separate from the cylinder itself. Try jiggling the key a bit to see if you can get it to work at all. Otherwise, I would start looking at the sensors/wiring.
'98 S70 T5
2k2wranglerx
can you pull the column cover to gain access to the electrical? i might just do that anyway since it's sitting in my warm garage on jackstands (tires are getting mounted).jblackburn wrote:It would be the electrical portion of that ignition switch, which is separate from the cylinder itself. Try jiggling the key a bit to see if you can get it to work at all. Otherwise, I would start looking at the sensors/wiring.
