Car won't start awaiting rebuilt ABS module...
plumsmooth
Year and Model: V70 Wagon 2004
Post by plumsmooth »
Car has been sitting quite a bit over the last couple of weeks and is low on gas.
Before I study the "will not start" flow chart, can anyone think of anything I may have damaged while removing the air filter and housing a couple of times and fiddling around in the chassis under and around the ABS module which I removed?
Has thanked: 1609 times
Been thanked: 4064 times
Dislodged coil wires or cap/rotor on distributor.
plumsmooth
Update car is starting.
I used some IPA dry gas and added a gallon of regular and it started.
However I notice my Air Intake hose to the Air Filter Housing Assembly was off too.
I believe Air Intake can effect Car starts?
It has been humid here I have barely run her in Two weeks.
I think old cars like to be run...
They can be fussy to start after major work. My 1999 took 30 seconds of cranking after PvC service
Crank for 5 seconds, wait 20.... Repeat.
