Matt Members Saved Me $2500.00!
corriganl
Year and Model: 1998
Post by corriganl »
After getting the "no compression" diagnosis from my mechanic he offered to replace my 2.4L engine with a used one for $2500. I was shocked because the car ran fine when I moved it from the garage onto the street the night before. How could a "no start" problem be this catastrophic?
I did what I often do then, I came to Matt and searched "no compression". All I can say now is that "lawnmower syndrome" is alive and well in my S70. I called my mechanic and told him to pour a tablespoon of oil in each banger, change the oil and plugs and then try to fire her up. Sure as I am writing this thank-you, all 5 cylindars where purring away as only 358K kilomerters could sing.
You guys are awsome! BTW, after welding my driver door hinge twice I used the forum too and bolted it this time....that was over a year ago and it's still holding. Thanks guys....now I can afford next simesters tuition :lol:
S70 Dad
jblackburn
Year and Model: 1998 S70 T5
Has thanked: 9 times
Been thanked: 19 times
Post by jblackburn »
Great news to hear! Congratulations.
These are strange cars sometimes, but having a helpful forum for any vehicle makes all the difference.
'98 S70 T5
2016 Chevy Cruze Premier
matthew1
Site Admin
Year and Model: 850 T5, 1997
Has thanked: 2660 times
Been thanked: 1248 times
Post by matthew1 »
Great to hear about situations like this. Really nice.
Also -> Amazon link
rspi
Has thanked: 34 times
Been thanked: 72 times
Post by rspi »
Is it really necessary to change the oil and plugs?
taxi
Year and Model: V70 2000
Post by taxi »
Not really, if you disconnect injectors, put some oil in the cylinders (cold start=very rich mixture=washes oil away wich is needed for compression) and crank a bit, reconnect injectors and start the car!
When you dont disconnect injectors, fuel leaks down into crankcase, due to lack of compression/worn rings. I think that is why you change the oil, it becomes contaminated to some degree.
Disconnecting injectors is cheaper and faster than changing oil.
I dont know about the spark plugs though?
corriganl
Post by corriganl »
The CAA (same as AAA) came to tow the car to the garage but before he hooked it up, he tried cranking it over quite a few times before he realized it was not going to start. Not knowing what the problem was, he didn't disconnect the injectors so I thought it would be safe to change the oil.
The plugs were at half life so I figured I would have them changed while it was in.
S70 Dad
