96 850 GLT Brake Pad, OEM or aftermarket?
joe_pinehill
Year and Model: 850 1996
Volvo Repair Database 96 850 GLT Brake Pad, OEM or aftermarket?
Post by joe_pinehill »
I'm going to do the pads on my 850, are OEM the best for minimal noise? $75 and $40 for OEM from FCP, or are Raybestos, Beck Arnley , as good? The difference is about $40 vs OEM.
96 850 GLT
RIP '90 240 DL, 285K, someone ran a stop sign in front of me
RIP '89 760 Wagon, 200K
RIP '83 240 Wagon, rusted out
instarx
Year and Model: XC70 T6 2011
Has thanked: 1 time
Post by instarx »
I won't pretend to have knowledge of all those pads, but I put Akebono ceramic pads and ATE rotors on mine and the combination has been great. No dust, no squealing and three years later they still stop smooth as butter. They were $65 for the front pads, $128 for the rotors including shipping. Shipping on rotors can get pricey - get them locally if you can.
2011 XC70 T6 - current
2017 Alfa Romeo Giulia Q2 - Totaled in 2022. Not my fault.
2011 XC60 - sold
2000 V70XC - given to a friend, wish I still had it.
jreed
Has thanked: 352 times
Been thanked: 192 times
Post by jreed »
I used to use OEM front pads but was dissatisfied with all the dust they produced. I switched to Akebono pads (leaving the rotors as they were) about four years ago. They're great. Little or no dust, good braking power. Recommended!
jblackburn
Year and Model: 1998 S70 T5
Has thanked: 9 times
Been thanked: 19 times
Post by jblackburn »
Akenbono's are a fantastic match for this car, but not a good match for the OEM rotors. You'll want something a little harder (Zimmerman was my choice).
'98 S70 T5
2016 Chevy Cruze Premier
regent
Year and Model: 2015 XC60 T5
Has thanked: 2 times
Been thanked: 12 times
Post by regent »
I've had great experience with Akebono Euro Ceramic on either Brembo or Zimmermann on every change. There are online suppliers who offer free shipping. Just shop around among FCP, ecstuning.com, autohausaz.com, etc. before you opt for a local source.
Also, it is vital that you do a nice bedding-in as soon as you install, regardless of what the rumors say. Overall job cleanliness and application of good brake grease (sparingly 8) ) on caliper pins, fingers, and bracket sliders works miracles in noise minimization.
2015 BMW 335i
2015 XC60 T5 Premier Plus
2002 S60 2.4 n/a - retired :(
1987 340 DL - retired :(
instarx
Has thanked: 1 time
Post by instarx »
regent wrote:Also, it is vital that you do a nice bedding-in as soon as you install, regardless of what the rumors say.
Since Akebono goes to the trouble of putting an insert in the box saying NOT to do bedding-in, its a bit more than a rumor.
2011 XC60 - sold
oragex
Year and Model: S60 2003
Has thanked: 102 times
Been thanked: 352 times
Post by oragex »
instarx wrote:I won't pretend to have knowledge of all those pads, but I put Akebono ceramic pads and ATE rotors on mine and the combination has been great. No dust, no squealing and three years later they still stop smooth as butter. They were $65 for the front pads, $128 for the rotors including shipping. Shipping on rotors can get pricey - get them locally if you can.
I will never put again ceramic pads on a city/highway driven car. The only place for ceramic pads is on hill areas or at the track. In city, compared with semi-metallic pads, the ceramic ones have no time to heat up and braking power and distance are worst. And ceramic tend to be noisier. Only advantage is cleanliness.
jblackburn
Haven't had any of those problems with the Akebonos - maybe they're a less aggressive ceramic compound that doesn't need to heat up to brake effectively, and they certainly deal with heat from heavy braking much better than the stock Volvo pads.
In fact, my new car has ceramic pads on it from the factory. Stops just fine...cold, anyway. They're not great hot because the rotors are stupidly small.
'98 S70 T5
xHeart
Year and Model: 2.0/3.2
Has thanked: 113 times
Been thanked: 115 times
Post by xHeart »
jblackburn wrote:Akenbono's are a fantastic match for this car, but not a good match for the OEM rotors. You'll want something a little harder (Zimmerman was my choice).
jreed wrote:I used to use OEM front pads but was dissatisfied with all the dust they produced. I switched to Akebono pads (leaving the rotors as they were) about four years ago. They're great. Little or no dust, good braking power. Recommended!
Akebano on Zimmerman are steady and smooth, and quick if you want. I would service the calipers with cn90's write up, brake-lines per Jreed's at this age.
oragex
Post by oragex »
It is certain that when heavy braking is involved, such as in a mountain area, ceramic brakes are almost a must to dissipate the heat. Perhaps like you say there are certain brands that work better on ceramics.
