96 850 GLT Brake Pad, OEM or aftermarket?
joe_pinehill
- Year and Model: 850 1996
I'm going to do the pads on my 850, are OEM the best for minimal noise? $75 and $40 for OEM from FCP, or are Raybestos, Beck Arnley , as good? The difference is about $40 vs OEM.
96 850 GLT
RIP '90 240 DL, 285K, someone ran a stop sign in front of me
RIP '89 760 Wagon, 200K
RIP '83 240 Wagon, rusted out
- instarx
- Year and Model: XC70 T6 2011
I won't pretend to have knowledge of all those pads, but I put Akebono ceramic pads and ATE rotors on mine and the combination has been great. No dust, no squealing and three years later they still stop smooth as butter. They were $65 for the front pads, $128 for the rotors including shipping. Shipping on rotors can get pricey - get them locally if you can.
2011 XC70 T6 - current
2017 Alfa Romeo Giulia Q2 - Totaled in 2022. Not my fault.
2011 XC60 - sold
2000 V70XC - given to a friend, wish I still had it.
2011 XC60 - sold
- jreed
- Has thanked: 352 times
- Been thanked: 192 times
I used to use OEM front pads but was dissatisfied with all the dust they produced. I switched to Akebono pads (leaving the rotors as they were) about four years ago. They're great. Little or no dust, good braking power. Recommended!
jblackburn
- Year and Model: 1998 S70 T5
- Has thanked: 9 times
- Been thanked: 19 times
Akenbono's are a fantastic match for this car, but not a good match for the OEM rotors. You'll want something a little harder (Zimmerman was my choice).
'98 S70 T5
2016 Chevy Cruze Premier
- regent
- Year and Model: 2015 XC60 T5
- Has thanked: 2 times
- Been thanked: 12 times
I've had great experience with Akebono Euro Ceramic on either Brembo or Zimmermann on every change. There are online suppliers who offer free shipping. Just shop around among FCP, ecstuning.com, autohausaz.com, etc. before you opt for a local source.
Also, it is vital that you do a nice bedding-in as soon as you install, regardless of what the rumors say. Overall job cleanliness and application of good brake grease (sparingly
) on caliper pins, fingers, and bracket sliders works miracles in noise minimization.
2015 BMW 335i
2015 XC60 T5 Premier Plus
2002 S60 2.4 n/a - retired
1987 340 DL - retired
2015 BMW 335i
- instarx
Since Akebono goes to the trouble of putting an insert in the box saying NOT to do bedding-in, its a bit more than a rumor.regent wrote:Also, it is vital that you do a nice bedding-in as soon as you install, regardless of what the rumors say.
2011 XC60 - sold
2011 XC60 - sold
- oragex
- Year and Model: S60 2003
- Has thanked: 102 times
- Been thanked: 352 times
I will never put again ceramic pads on a city/highway driven car. The only place for ceramic pads is on hill areas or at the track. In city, compared with semi-metallic pads, the ceramic ones have no time to heat up and braking power and distance are worst. And ceramic tend to be noisier. Only advantage is cleanliness.instarx wrote:I won't pretend to have knowledge of all those pads, but I put Akebono ceramic pads and ATE rotors on mine and the combination has been great. No dust, no squealing and three years later they still stop smooth as butter. They were $65 for the front pads, $128 for the rotors including shipping. Shipping on rotors can get pricey - get them locally if you can.
jblackburn
Haven't had any of those problems with the Akebonos - maybe they're a less aggressive ceramic compound that doesn't need to heat up to brake effectively, and they certainly deal with heat from heavy braking much better than the stock Volvo pads.oragex wrote:I will never put again ceramic pads on a city/highway driven car. The only place for ceramic pads is on hill areas or at the track. In city, compared with semi-metallic pads, the ceramic ones have no time to heat up and braking power and distance are worst. And ceramic tend to be noisier. Only advantage is cleanliness.instarx wrote:I won't pretend to have knowledge of all those pads, but I put Akebono ceramic pads and ATE rotors on mine and the combination has been great. No dust, no squealing and three years later they still stop smooth as butter. They were $65 for the front pads, $128 for the rotors including shipping. Shipping on rotors can get pricey - get them locally if you can.
In fact, my new car has ceramic pads on it from the factory. Stops just fine...cold, anyway. They're not great hot because the rotors are stupidly small.
'98 S70 T5
xHeart
- Year and Model: 2.0/3.2
- Has thanked: 113 times
- Been thanked: 115 times
jblackburn wrote:Akenbono's are a fantastic match for this car, but not a good match for the OEM rotors. You'll want something a little harder (Zimmerman was my choice).
Akebano on Zimmerman are steady and smooth, and quick if you want. I would service the calipers with cn90's write up, brake-lines per Jreed's at this age.jreed wrote:I used to use OEM front pads but was dissatisfied with all the dust they produced. I switched to Akebono pads (leaving the rotors as they were) about four years ago. They're great. Little or no dust, good braking power. Recommended!
- oragex
It is certain that when heavy braking is involved, such as in a mountain area, ceramic brakes are almost a must to dissipate the heat. Perhaps like you say there are certain brands that work better on ceramics.jblackburn wrote:Haven't had any of those problems with the Akebonos - maybe they're a less aggressive ceramic compound that doesn't need to heat up to brake effectively, and they certainly deal with heat from heavy braking much better than the stock Volvo pads.oragex wrote:I will never put again ceramic pads on a city/highway driven car. The only place for ceramic pads is on hill areas or at the track. In city, compared with semi-metallic pads, the ceramic ones have no time to heat up and braking power and distance are worst. And ceramic tend to be noisier. Only advantage is cleanliness.instarx wrote:I won't pretend to have knowledge of all those pads, but I put Akebono ceramic pads and ATE rotors on mine and the combination has been great. No dust, no squealing and three years later they still stop smooth as butter. They were $65 for the front pads, $128 for the rotors including shipping. Shipping on rotors can get pricey - get them locally if you can.
