But... my crusie control still isn't working, I was thinking after fixing the ABS problem would fix the cruise but it didn't.. any ideas where to start on this problem ??
96 volvo 850R cruise control not working
- phils94850
- Year and Model: 2009 s60 turbo
I had a ABS light on my dash so I decided to open up the module and re-solder the joints and I also ohm tested my wheel abs sensors and found my right rear sensor was bad. I replaced the rear sensors and no more ABS light
1996 Platinum Edition
- Has thanked: 311 times
- Been thanked: 817 times
The issue may be the ABS module, but if not:
By far most common problem is that vacuum line under the battery tray, the rubber elbow rots out so it doesn't hold a vacuum. Then probably the brake switch, but it could be elsewhere too.
There is a terrific troubleshooting guide in the Volvo manual, to systematically test each component. It is a 95 manual so you can't run the OBD box tests on your 96, but otherwise will be totally accurate for your car (e.g. jumper tests for the relay and the pump), download it from here:
https://www.matthewsvolvosite.com/downlo ... vo_850.zip
Once you unzip it there is a file called cruise control system.pdf, look there.
mecheng
- Has thanked: 15 times
- Been thanked: 21 times
Check that the rod ball joint is attracted to your gas pedal. My came off, 2 min fix
1997 Volvo 850 GLT - 190km
Boost is my drug of choice
That's a good tip, have never heard of that one!
- phils94850
thanks guys... im gonna give it a good look over today
- phils94850
ok.. i checked everything per the volvo repair manual.. i can remove the cruise control module and use a jumper wire and make the cruise control pump come on and suck down and hold my gas pedal so i know all that is working. I also checked the input and output of my cruise control switch and its working so im guessing the module is bad.
Is it often these modules go bad ??
When I thought it was the module it wasn't, turned out to be a leaky vac line. But yours I can't figure.
I can send you a working module no charge, shoot me a PM if you want it.
- 5279 Views
Last post by THeOldMan
- 700 Views
Last post by howardc64
- 32 Replies
- 9833 Views
Last post by zhenya
- 718 Views
Last post by Denwiley
- 1265 Views
Last post by RickHaleParker
