Request: CAN frame capture
Year and Model: S60
Post by 67726567 »
Hello,
I am a long time lurker on this forum. I'm reaching out in hopes that someone here may be able to perform a CAN capture of their P2 XC90 for me to analyze.
Here is the story:
I have a 2013 XC90 that was shipped from Volvo with a B6304S and a TF80-SC.
I have installed a B6304T4 from a 2013 S60 into the car along with the XC's original TF80.
I have the engine where it will start and idle using aftermarket engine management.
I need the CAN dump from an operable XC90 in my original configuration so that I can determine the frames required by the TCM so that I can hopefully drive the vehicle sooner than later.
Please respond if you are able and willing to help with this request.
Thank you in advance.
dikidera
Year and Model: S60 2005
Has thanked: 67 times
Been thanked: 175 times
Post by dikidera »
What seems to be the trouble specifically? Which function isnt working?
67726567
Year and Model: S60
Post by 67726567 »
The transmission is not going to work after I removed the Denso ECM and installed a EcuMasters EMU PRO to run a B6304T4 from a 2013 S60.
67726567
Year and Model: S60
Post by 67726567 »
The TCM relies on CAN frames sent from the ECM to choose the correct shifting strategy.
Fames that I know it needs:
- Brake switch status
- Engine oil temperature
- Throttle position
I'm sure that there are more.
But I either get a CAN dump from an operable vehicle or I have to figure out how to ROM dump the TCM.
Or, replace the TCM with a standalone but I'd rather not do that unless I have to.
dikidera
Post by dikidera »
There are many more. Cruise Control status, Engine RPM, most importantly, torque control/torque reduction, without a reply from the ECM with the changed torque it will likely go into limp mode(not confirmed tho).
It also reads Vehicle Speed from ABS over CAN.
67726567
Year and Model: S60
Post by 67726567 »
Okay, well that's why I've asked for a CAN frame capture from someone willing and able to obtain it
67726567
Year and Model: S60
Post by 67726567 »
FYI, the EcuMasters EMU PRO can build CAN frames. I have it connected to the Volvo high speed CAN and I also have a P-Can that I can do my own captures with but never did that (very unfortunately) before I began swapping the engines because I had a fundamental misunderstanding of the difference in the files loaded on each ECM.
They were both Denso MB279700-9500s.
However, when I got the flash pulled with a K-Tag on the bench, I realized that the instruction flash was different as well.
Call it naivete, but I had hoped that the security routine was in the bootloader. I do not believe that's the case. And due to the fundamentally different types of security systems on a P2 XC90 and a P3 S60, I decided to replace the ECM and just ignore the immobilizer that way.
67726567
Year and Model: S60
Post by 67726567 »
Well, I managed to drive it anyway. Not very far and there is a HARD shift to drive (RPM too high, brake pedal status not sent, IDK???)
Anyway, here it is:
