For remote programming you don't need to touch CEM (only if you going to add another transponder aswell).poteroa wrote: ↑14 Feb 2026, 11:15 Hi all.
Quite massive page count on this topic..
Have a question, and maybe someone can answer directly without need to go through 430 pages
Just read the CEM on a V70, 2001 and looking for the PIN. (And IMMO code of course if it is possible to decode from there)
I used the kaev´s Arduino BDM soft, the only problem is that you can not save the read binary with that software.
https://volvo-tech.com/en/793-2/ (Used Arduino UNO for this, as it was easily available).
Going through the peoples replys, I found info that the PIN should be located in address 0x04E000 is this right?
Do not see any sense to buy expensive programmer just for getting one remote programmed to otherwise cheap car.
Anyone able to help on this?
Oh, the CEM unit is HW-PN: 9452596
Other markings: 8645697/01W075
And for saving the bin just use copy paste
CEM pin 0x4000 or 0x6000
