IPD sale XeMODeX - Experts in Volvo Electronics
Did you know? 🤔
Logged in users can get email notification of topic replies Log in or register (free).
Amazon Link Buy your stuff using this and it helps MVS!
2005 XC90, No fuel pressure
Help, Advice, Owners' Discussion and DIY Tutorials on Volvo XC90s. The XC90 proved to be very popular, and very good for Volvo's sales numbers, since its introduction in model year 2003 (North America).
volvooh
Year and Model: '98 S70, '05&'08 V70
Has thanked: 0
Been thanked: 2 times
United States of America
volvooh
Post by volvooh » Mon Aug 05, 2019 6:32 am
After arriving back home last night for a quick drive in the XC90, I went out to move it in the driveway and it would not start. Felt initially like it was get fuel but could not remain started.
Later, I checked pressure at the rail, and found it to be zero. I did not have access to my code reader. I have not encountered any diminished performance such as hesitation leading up to this event.
I have owned the car for a month, has 173,xxx mi and has been running quite well to this point.
I am going to start with the relay, and try to jump it first. I feel like the sudden onset points to relay, fuel module or fuel pump. I just don't think a fuel filter would be the culprit here.
Any thoughts are appreciated!
volvooh
Has thanked: 0
volvooh
Re: 2005 XC90, No fuel pressure
Post by volvooh » Mon Aug 05, 2019 11:28 am
Is there a fuel pump relay on the '05 XC 90 or is it all handled by the PEM? I did not find a relay on the CEM under the d-side dash.
ggleavitt
Year and Model: XC90 05-2.5T, 08-V8S
Has thanked: 0
Been thanked: 55 times
ggleavitt
Post by ggleavitt » Mon Aug 05, 2019 12:02 pm
Some info here- viewtopic.php?f=10&t=83957&start=10#p460721 , PEM manages the pump based on PWM signal from the ECM (demand controlled pump). CEM provides DC feed.
This is a 2005 so PEM is external unless someone has already moved it in the vehicle- https://forums.swedespeed.com/showthrea ... M-Location
2005 2.5T AWD-198k
2008 V8 AWD Sport-129k
Roger_850T
Year and Model: 854T 1995
Has thanked: 0
Been thanked: 12 times
Roger_850T
Post by Roger_850T » Mon Aug 05, 2019 8:28 pm
I agree. 0 fuel pressure measured at the rail points to a fuel pump issue, and the question is: is the pump not running, or is there an obstruction that prevents the fuel from flowing. ViDA will indicate what the CEM *thinks* the PEM is doing. See if you can find the fuel pump. If the pump is running, then that suggests obstruction (or some sort of reason why the pump isn't being very effective), or if the pump is not running, that's a different path to chase down. I do like measuring the pressure at the shraeder valve on the fuel rail - that's pretty definitive.
Roger
'05 XC90 V8 140k
'95 854T 310k
'02 V70 159k
'03 S80 111k (crashed)
'93 945T 217k (gone to be parted out)
'87 245 300k+ sold, still going
'84 264 Diesel, RIP at 160k
'78 242 manual everything.
'73 P1800ES, fun until the rust set in...
wanderdüne
Year and Model: 2004, 2006 XC90 2.5T
Has thanked: 4 times
Been thanked: 25 times
wanderdüne
Post by wanderdüne » Mon Aug 05, 2019 8:31 pm
If it's a 2.5T, it also has a fuel pressure sensor at the end of the rail, for what it's worth.
volvooh
Has thanked: 0
volvooh
Post by volvooh » Tue Aug 06, 2019 7:30 am
Thank you all. I was able to get my code reader, and no codes. I chased down the PEM...for other 05'ers that experience this, it was located on the underside of the SUV right next to the fuel filter (This discovery was after removal of both rear wheels and fender skirts along with a long search through the trunk area). I really can't think of a worse possible location for an electronic device that does not even look like its sealed.
My son drives an 08 S60. His PEM was relocated to the trunk of his vehicle (and actually is using the Ford equivalent PEM) . A quick swap out of his PEM to mine and the fuel pump began to hum and the vehicle started right-up. Ordered a pull-off from Ebay for $49.99 from a donar vehicle with PEM located inside the car. I looked for the kit to move it inside and not finding it. Probably will replace it where it sits for now so that I can get it on the road and continue to look for kits for a future relocation.
ggleavitt
Has thanked: 0
ggleavitt
Post by ggleavitt » Tue Aug 06, 2019 1:02 pm
https://forums.swedespeed.com/showthrea ... he-harness , my '05 also has the PEM next to the fuel filter. I believe fuel tank size (68/72 vs 80) is the differentiator for location.
Harness is PN 8688667 as noted in the post above. Your original PEM lasted 15 years, you could in theory leave the "new" one where it is and do a bead of silicone around the snap-on top then some dialectric grease on the connector. Personally I would move the inside so it's done (harness or a good and sturdy splice) but you have some options for promoting longevity should you decide otherwise. My PEM is still outside the vehicle, can see photos in the second link in teh earlier post (it's in great shape).
2005 2.5T AWD-198k
Year and Model: 2004 V70 2.5T
Has thanked: 0
Been thanked: 121 times
Post by cn90 » Fri Aug 16, 2019 7:49 am
My 2005 XC90 2.5T with 120K still has the original PEM. I have a used PEM from junk yard. I keep the used PEM in the trunk as spare, just in case.
oragex
Year and Model: S60 2003
Has thanked: 92 times
Been thanked: 228 times
Canada
oragex
Post by oragex » Sat Aug 17, 2019 6:35 am
The PEM is also sometimes located on the XC90 inside the right rear wheel well https://volvoforums.com/forum/volvo-xc9 ... ial-71534/
volvooh
Has thanked: 0
volvooh
Post by volvooh » Thu Aug 22, 2019 1:49 pm
Just my luck that is where I started. Looked in one wheel well, then another, then all through the truck, then finally on the underside of the car, where it sat. I spent more time looking for it than actually fixing it.
