hi Topic is solved
1975 - 1993 240
1983 - 1992 740
1982 - 1991 760
1986 - 1991 780
1990 - 1998 940
1990 - 1998 960
1997 - 1998 V90/S90
toycorolla78
hi
Post by toycorolla78 »
WELL, I THINK IF YOU CONNECTED PROPERLY AND VERY WELL THE FRONT LIGHT (TURN SIGNAL) AND... YOUR TURN SIGNAL ON THE BACK IS GOOD THE PROBLEM IS THE RELAY. BECAUSE YOU GAVE SIGNAL LIGHT "ON" ON YOUR PANNEL THAT MEANS IS ELECTRICITY OK. TRY TO UNPLUG THE BATERRY TERMINALS AND CLEAN THEME AND THE POSTS THEN TRY AGAIN IF STILL THE SAME CHANGE DE RELAY !!!
