hi
toycorolla78
hi
WELL, I THINK IF YOU CONNECTED PROPERLY AND VERY WELL THE FRONT LIGHT (TURN SIGNAL) AND... YOUR TURN SIGNAL ON THE BACK IS GOOD THE PROBLEM IS THE RELAY. BECAUSE YOU GAVE SIGNAL LIGHT "ON" ON YOUR PANNEL THAT MEANS IS ELECTRICITY OK. TRY TO UNPLUG THE BATERRY TERMINALS AND CLEAN THEME AND THE POSTS THEN TRY AGAIN IF STILL THE SAME CHANGE DE RELAY !!!
