charging 240 ac Topic is solved
1975 - 1993 240
1983 - 1992 740
1982 - 1991 760
1986 - 1991 780
1990 - 1998 940
1990 - 1998 960
1997 - 1998 V90/S90
cantstop
charging 240 ac
Post by cantstop »
i atempted to charge the ac on a 1990 240 volvo rthrough the scrader valve on the receiver drier,and expected a cap,instead the whole valve? came out like a plug just leaving ascrew whole.is this not the low side charge location or is there another port.if it is the charge port,where can one get the needed adaptor?thank you[size=18][/size]
JayB
Post by JayB »
I think that's some sort of relief valve. I have had to charge through the port on the back of the compressor. I have a replacement compressor, but they might all have one. Make sure you use the one on the suction side and not the discharge (you probably already knew that).
