A quick check for the fuel relay is to put your finger on it then switch on the ignition. You should feel a click. Do that two or three times.
To listen for the in-tank pump you need an assistant. Remove the fuel filler cap and put your ear as near as possible to the hole. Your assistant should now switch on the ignition, without starting the engine, and you should hear, momentarily, a buzz from the pump. Once it has primed the system it stops until the fuel in the pipe between that pump and the main pump needs to be replenished.
To replace the pump is fairly easy as the nice people at Volvo have made it accessible from the luggage area. Remove the carpet and you will see an access cover.
A large number as the manual transmission was standard in the UK and, as far as I know, Europe.This 240 is a 5 speed too, I wonder how many of them they made.
Bill.
