96 960 engine ticking Topic is solved
1975 - 1993 240
1983 - 1992 740
1982 - 1991 760
1986 - 1991 780
1990 - 1998 940
1990 - 1998 960
1997 - 1998 V90/S90
CIK7
Year and Model: 95 854T & V70trailer
Has thanked: 330 times
Been thanked: 87 times
Post by CIK7 »
I have ticking at the top of my engine and someone's resolution was to change the oil with 10 w 30 synthetic and it seems that it worked for a bunch of people but it did not solve the problem for me. The engine is still ticking. I've heard that this is just lifters, which makes sense, but I want to know multiple solutions to the ticking.
09 Rav4 Ltd3.5Fwd, red, 208.5k/213k, sold
96 964 silver, 146K, diff&trans/engine self-destr, crushed 😭
RickHaleParker
Been thanked: 958 times
Post by RickHaleParker »
Ticking lifters on the older six cylinders is a common issue. The O-ring on the oil pick up tube goes defective. When this happens it is like sucking on a straw with a hole in it. Not enough oil gets to the lifters to keep them pumped up. Solution ... new O-ring for the oil pick up tube.
CIK7
Post by CIK7 »
RickHaleParker wrote: 21 Aug 2020, 00:28 Ticking lifters on the older six cylinders is a common issue. The O-ring on the oil pick up tube goes defective. When this happens it is like sucking on a straw with a hole in it. Not enough oil gets to the lifters to keep them pumped up. Solution ... new O-ring for the oil pick up tube.
Thank you so much!
