1992 240 radio wiring diagram Topic is solved
Hi, as you probably know, you actually don't have to know anything about connections, because it exist ready made cables harness for connection between Volvo wire harness and the plugs used as standard of the car stereo manufactures around the world. If you want to cut the wires, I will give you the colors:
SB = ground
GN = const
Y-SB = B+ (battery)
R = power antenna
Y-W = Left front speaker +
W = Left front sp -
Y-GR = Right front sp +
GR = Right front sp -
As you can see, this Volvo do only have 2 speakers in origin.
If your Volvo have 4 speakers as origin, you can see the system in the colors, Y-GR = + and GR for - , you will always see one 2-color wire for the + and minus will have one of the colors from the + wire.
SB = ground
GN = const
Y-SB = B+ (battery)
R = power antenna
W = Left front sp -
lummert
- Year and Model: 760 1988
- Been thanked: 26 times
You may find something here:Foxdie wrote:Does anyone have the pin locations for the wiring harness for the oem radio? I have been in a bit of nostalgia and would like to have to have my tape deck and radio work ...going from a aftermarket to oem
www.volvowiringdiagrams.com
1988 Volvo 760 Turbo Wagon
- 2705 Views
Last post by legalstuff
- 1875 Views
Last post by difflock54
- 2475 Views
Last post by Adam_Leyva
- 364 Views
Last post by 1992vt240
- 607 Views
Last post by mar601
