740 Intertiment Starting Problem Topic is solved
1975 - 1993 240
1983 - 1992 740
1982 - 1991 760
1986 - 1991 780
1990 - 1998 940
1990 - 1998 960
1997 - 1998 V90/S90
watchdog
Post by watchdog »
Hi:
Thanks for any input you are willing to provide
A.Baker
Year and Model:
Post by A.Baker »
I just bought an 87 740t and the previous owner had the same concern. He switched to high test fuel and the problem went away. I on the other hand am CHEEP and bought regular gas and now I have a no start after a 10 min. or less hot soak. The turbo has been removed so heat from that is not the cause.
Good luck.
A. Baker
Guest
Post by Guest »
:D hello there i had that problem it's one or two things check your motor fly wheel just had mine replace because some times it started and sometimes it didn't also i had a bad computer which also was replaced good luck
A.Baker
Year and Model:
Post by A.Baker »
The problem you are haveing sound like the one I had. At the end of all the testing I found that the sensor below the intake manifold between #3 and 4 was bad. That sensor tells the the computer it the car what temp. the engine is. and adjusts the fuel/air mix accordingly. I also found that the ecm under the r/side kick panel had some dammaged pins that were easy to clean. Hope this helps.
A.Baker
