Was driving home tonight and while I was accelerating a bit up a hill, I heard a scraping noise, almost like something was scraping across the ground. After a few seconds, this went away, this is the second time this has happened, first time was a few weeks ago. I thought that maybe it might be the transmission... I checked and nothing was scraping the ground. Now, I know trans fluid should be changed every time a tuneup is performed, but when I had a major tuneup and carrier bearing replaced, I inquired about the transmission and was told to leave it alone.
Here's another thing though, ever since I've had the car, the gas pedal has always been a little tougher to push than I'd like it to be and also sometimes in order to get to the next gear, I have to slightly lift my foot off of the gas to nudge it along, but other times it's fine. Just wondering if this is all related. Have been thinking of dropping the transmission pan, replacing filter, gasket and fluid but I worry that the old shavings and whatnot are what's keeping the thing running.
Have not checked the trans fluid yet, will do so tomorrow and post back.
Also, the V6 760GLE takes Dexron III?
Thanks a lot!
Darrell
