CD changer head unit with AM/FM. Sharkfin Antennae. Only Static on AM/FM.
Where would you start?
2006 S40. -Only Static on AM/FM
spatacuulous
- Year and Model: 2006 S40
- MoVolvos
- Has thanked: 310 times
- Been thanked: 524 times
.spatacuulous wrote: ↑08 Aug 2025, 08:18 CD changer head unit with AM/FM. Sharkfin Antennae. Only Static on AM/FM.
1) Pull unit and see if antenna has come loose or corroded.
2) Check connection / wiring at Sharkfin.
3) If available check the head unit by connecting a whip antenna directly to see if you have signal.
spatacuulous
1) Pull unit and see if antenna has come loose or corroded - Its got the waterfall dash/radio. I dont see a specific antennae cable like in the old school days - I just see two plug connectors going in there. I jiggled - unplugged and plugged. Nothing.
There is a very faint radio station on some of the strongest stations.
2) Check connection / wiring at Sharkfin - Can I remove from the roof or have to drop the headliner?
3) If available check the head unit by connecting a whip antenna directly to see if you have signal - Not sure which wire is the sharkfin.
Thank you for your suggestions/help.
