Alternative To Rivets?
How to go faster, stop quicker, and turn harder. Chips, exhaust, larger turbos, bigger/slotted/drilled rotors, high performance brake pads, manual boost controllers, performance shocks/struts/springs, airbox mods and more! Also discussion on HID and Xenon lights, aftermarket foglights and other exterior lighting.
MoVolvos
Has thanked: 310 times
Been thanked: 524 times
Post by MoVolvos »
Use black ties and black electrical tape wrapped over washers? Cheaper than faster than rivets?
Has thanked: 1850 times
Been thanked: 1710 times
AS it says, temporary fastener. Using a regular aluminum rivet or zip-tie on a mudflap will end badly if it hits anything. Instead of peeling over the plastic coated Volvo rivet, it will bend your fender as far as the headlight if you are unlucky.
