IPD sale XeMODeX - Experts in Volvo Electronics Free shipping all USA - Experts in Brakes
Did you know? 🤔
Logged in users can get email notification of topic replies Log in or register (free).
Amazon Link Buy anything with this and it helps MVS!
P0014 & P0015
1996 - 2004 S40
1996 - 2004 V40
AU-S40
Year and Model: S40, 2000
Has thanked: 0
Been thanked: 0
AU-S40
P0014 & P0015
Post by AU-S40 » Mon May 28, 2012 11:59 pm
My 2000 S40 was reporting P0014 (Timing Over-Advanced/System Performance), P0015 (Timing Over-Retarded), P0507 (Idle RPM higher than expected), and a P0303 (Cylinder 3 Misfire). These were all with a generic scanner. I have a DiCE ordered, but it has not come in yet. I took it to a local shop and they replaced the VVT-Solenoid. Everything was OK for about a day, and then P0014 and P0015 came back. Today the P0303 came back as well. Any ideas on what to check next? I have no symptoms other than very hard starting and sometimes rough idling for a few minutes after cranking, both of which still occur after the solenoid replacement.
jimmy57
Has thanked: 3 times
Been thanked: 233 times
jimmy57
Re: P0014 & P0015
Post by jimmy57 » Tue May 29, 2012 9:36 am
Those codes set because the cam timing was under and over target. CVVT solenoid can cause this as can a sticking CVVT actuator/gear hub assy.
IS the engine clean inside as far as you can tell?
SInce solenoid was replaced the hub is the likely item causing troubles.
AU-S40
Has thanked: 0
Been thanked: 0
AU-S40
Re: P0014 & P0015
Post by AU-S40 » Tue May 29, 2012 3:51 pm
AFAIK the engine is clean. I have not done that much under the hood, only on the interior. I will have him look at the hub. I did recently have a problem with the car leaking oil and if I remember correctly it was near the CVVT. I know the mechanic had to borrow a special tool to fix the timing. The check engine light came on shortly after that. Is there a chance that the timing may be off? He does not see a lot of Volvos. Would there be anything special about the timing that he might not have known?
AU-S40
Has thanked: 0
Been thanked: 0
AU-S40
Re: P0014 & P0015
Post by AU-S40 » Sun Jun 03, 2012 7:34 pm
If it helps any, I received my VIDA/DiCE package yesterday and the corresponding Volvo codes are ECM-60 and ECM-61. Are there any tests that I can run using VIDA? I also read about flushing the oil, a seal, or possibly the fuel pressure regulator? Would you recommend any of those? It has about 127,000 miles on it and I do not think we have ever used synthetic oil.
KLR142
Year and Model: 1991 244
Has thanked: 0
Been thanked: 0
United States of America
KLR142
Re: P0014 & P0015
Post by KLR142 » Tue Jan 19, 2016 6:32 pm
Sorry for the bump, but did you ever find a solution to your codes?
