AW55-50SN woes-easy to repair? Topic is solved
Repairing a AW55-50SN Transmission in a 2001 V70
cuhfs
- Year and Model: 850,XC70,XC90,S60,80
- Has thanked: 17 times
- Been thanked: 31 times
The 01 C70 is a manual transmission. The car which I sold and this transmission is from is a 04 C70 automatic. I still have one more of same car.
04 C70 Convert Auto
06 XC90 Auto (ORE) #401/800
06 S80
05 S80
12 S60
04 XC70 Auto (Parts car)
04 XC70 Auto (gone)
04 C70 Convert (gone)
06 S80
05 S80
12 S60
04 XC70 Auto (gone)
cuhfs
I am 95% sure the screen runs the whole space of the filter. I will open it 100% and see tomorrow. I will then play with solvents then too.
I dont think your idea as follows... will work: "My goal is to drill near the pick-up neck so I don't need to drill a hole in the filter at all".
There is some space where fluid flows thru already without the filter catching it. Obviously the flow is not enough. The transmission appears to need a flow ratio closer to the size of the filter surface. Not a few holes in the neck. You can see the neck (black plastic from behind the valve body (which you have obviously been behind a valve body or two
04 C70 Convert Auto
06 S80
05 S80
12 S60
04 XC70 Auto (gone)
06 S80
05 S80
12 S60
04 XC70 Auto (gone)
- Year and Model: Lots
- Been thanked: 128 times
That is disappointing to hear that fluid already gets through without contacting the filter. Are you certain as it makes little sense?? Nautic indicated in his T5 auto rebuild thread that ALL fluid passes through the filter.
Solvent in the cooler hose won't work to back flush. The fluid enters the pan beneath the filter at the steel hose with a 10mm bolt retainer.
Anyhow you are sleeping/ resting now and I begin work on this project now being midday here in Melbourne Australia. Photos to follow.
cuhfs
Friends just left so I grabbed the phone camera and tried to take a pic. Sorry for the poor quality, best I can do.precopster wrote: 30 Sep 2017, 18:59 That is disappointing to hear that fluid already gets through without contacting the filter. Are you certain as it makes little sense?? Nautic indicated in his T5 auto rebuild thread that ALL fluid passes through the filter.retainer.
If you can see the white line (plastic tie wrap) is used to show the flow area open and into to the area after the filter. So as best as I am able to understand what I see, Nautic may be incorrect.
04 C70 Convert Auto
06 S80
05 S80
12 S60
04 XC70 Auto (gone)
06 S80
05 S80
12 S60
04 XC70 Auto (gone)
cuhfs
Hard to explain,..Trying to show you... it all does not flow into the filter. The intake is not shown just the neck / mouth where it meets inside the transmission. Its open on both sides so it appears to me that some fluid is not filtered. The fluid can come into the filter from the bottom intake or from the backside of the mouth.
04 C70 Convert Auto
06 S80
05 S80
12 S60
04 XC70 Auto (gone)
06 S80
05 S80
12 S60
04 XC70 Auto (gone)
OK job is done. Hole was drilled in bell housing. I used a syringe with 80ml fluid twice to backflush any large pieces back into my 8mm hole then drain out.
First I went to 8mm hole then poked my skewer through then felt resistance. Pushed a little harder until something gave way......I suspect this was the filter mesh as another 200ml of fluid gushed out. I continued to push upward through the intake port of the filter and skewer was going all the way into the transmission. The skewer is about 14 inches long so I'm pretty sure the filter has been pushed aside.
Increased the hole size to 10.4mm which was perfect for my M12 x 1.75mm tap. Again used syringe to get any more pieces created by the tap but most of the pieces were running down the tap through the four ridges on the tap.
I now have M12 x 1.75mm bolt in there with a M18 crush washer capturing a rubber seal where the centre space is between bolt and crush washer.
cuhfs
Can't wait to hear about the test drive.
04 C70 Convert Auto
06 S80
05 S80
12 S60
04 XC70 Auto (gone)
06 S80
05 S80
12 S60
04 XC70 Auto (gone)
It's not blocked at the moment. Drives up and down the lane behind our house quite well. A longer drive awaits but I don't want to get stuck anywhere without towing support.
cuhfs
Understood about driving and getting stuck. Please update as you are able.
04 C70 Convert Auto
06 S80
05 S80
12 S60
04 XC70 Auto (gone)
06 S80
05 S80
12 S60
04 XC70 Auto (gone)
- Been thanked: 4064 times
Anxiously awaiting with popcorn. Hopefully the night stalking 'Roos don't get Mike...
Hope this one works out!!!
- 11 Replies
- 4360 Views
Last post by precopster
- 1730 Views
Last post by BEJinFbk
- 16 Replies
- 14668 Views
Last post by vt9000cse
- 1645 Views
Last post by dadyer
- 1095 Views
Last post by matthew1
