We have two loose and slippery key fobs for this XC. Easy to drop and I know they're expensive. Slightly beat up.
I was about to ask if there was a missing or broken bit on mine and took these pics, and quickly realized that's a diagonal hole through the corner, so you can run a ring or something through.
What are some original or clever things to attach it to? I have rings, carabiners, etc.
(Also - some mechanic glued our key blades open because the previous owner must have broken them and then the fob jammed the ignition - at least that's what the repair order says......?)
What is your key fob attached to? Topic is solved
- June
- Has thanked: 523 times
- Been thanked: 261 times
There is a chain with a swivel joint and a keychain on the end of that. My car has those same awful keys. I removed the keychain off of my daily use key and left it on the one I give to service. Do not hang keys or anything on that as it will cause your ignition switch to fail. June
My Volvo cars owned
1989 740 GLT ordered
1996 960 ordered
1998 V70 GT dealer stock car
2002 S80 T6 ordered totalled
1996 960 ordered
EngineeringBloke
- Year and Model: 2006 2.5T S60
- Has thanked: 55 times
- Been thanked: 39 times
I separated my Fob from all my other keys. I did not like the idea of a heavy weight on the ignition mechanism.
My Fob jammed closed when the spring broke. I was able to get it loose and now I just flip it open when I need to use it. Kind of miss the automated key blade opening, but I would not want them open all the time digging holes in my pockets.
Thought about fixing the mechanism, but have not tried it yet.
- BlackBart
- Has thanked: 927 times
- Been thanked: 884 times
I only ever carry a house key, so maybe it's not a deal.
Found a pic - looks like they came with a tiny D ring attached.
- June
I got my car back from service, so here is a picture of my factory key I left the keychain intact for the service department to put the hat number on. This is how the keys came from the factory. June
My Volvo cars owned
1996 960 ordered
1996 960 ordered
- BlackBart
Ah, thank you. I may fit the small ring and a very short cloth lanyard for something to grab in my pocket.
- Has thanked: 1505 times
- Been thanked: 3818 times
You want a short piece of line on that key fob in snow country, Bart
- BlackBart
A halyard perhaps....!
Or an avalanche cord so they can find me in the spring.
