What is your key fob attached to? Topic is solved
2001 - 2007 V70
2001 - 2009 S60
2003 - 2007 S60 R
2004 - 2007 V70 R
BlackBart
Has thanked: 927 times
Been thanked: 884 times
Post by BlackBart »
We have two loose and slippery key fobs for this XC. Easy to drop and I know they're expensive. Slightly beat up.
I was about to ask if there was a missing or broken bit on mine and took these pics, and quickly realized that's a diagonal hole through the corner, so you can run a ring or something through.
What are some original or clever things to attach it to? I have rings, carabiners, etc.
(Also - some mechanic glued our key blades open because the previous owner must have broken them and then the fob jammed the ignition - at least that's what the repair order says......?)
June
Has thanked: 523 times
Been thanked: 261 times
Post by June »
There is a chain with a swivel joint and a keychain on the end of that. My car has those same awful keys. I removed the keychain off of my daily use key and left it on the one I give to service. Do not hang keys or anything on that as it will cause your ignition switch to fail. June
My Volvo cars owned
1989 740 GLT ordered
1996 960 ordered
1998 V70 GT dealer stock car
2002 S80 T6 ordered totalled
EngineeringBloke
Year and Model: 2006 2.5T S60
Has thanked: 55 times
Been thanked: 39 times
Post by EngineeringBloke »
I separated my Fob from all my other keys. I did not like the idea of a heavy weight on the ignition mechanism.
My Fob jammed closed when the spring broke. I was able to get it loose and now I just flip it open when I need to use it. Kind of miss the automated key blade opening, but I would not want them open all the time digging holes in my pockets.
Thought about fixing the mechanism, but have not tried it yet.
BlackBart
Post by BlackBart »
June wrote: 04 Feb 2019, 16:45Do not hang keys or anything on that as it will cause your ignition switch to fail. June
Oh!
BlackBart
Post by BlackBart »
I only ever carry a house key, so maybe it's not a deal.
Found a pic - looks like they came with a tiny D ring attached.
June
Post by June »
BlackBart wrote: 05 Feb 2019, 10:46 I only ever carry a house key, so maybe it's not a deal.
I got my car back from service, so here is a picture of my factory key I left the keychain intact for the service department to put the hat number on. This is how the keys came from the factory. June
My Volvo cars owned
1996 960 ordered
BlackBart
Post by BlackBart »
Ah, thank you. I may fit the small ring and a very short cloth lanyard for something to grab in my pocket.
Has thanked: 1498 times
Been thanked: 3810 times
You want a short piece of line on that key fob in snow country, Bart
BlackBart
Post by BlackBart »
A halyard perhaps....!
Or an avalanche cord so they can find me in the spring.
