LOUD Running Gear Diagnosis Topic is solved
Kurturbanist
- Year and Model: 2002 v70xC
My 2002 v70 XC has gotten really loud at speeds over 40mph. I did drive over a Piece of lumber on the freeway and the left rear wheel seems to be the origin of the noise since then. When I turn more than 15 degrees or coast downhill it will quiet down briefly. The Volvo has 235K miles and rolls on new Pirelli Scorpions. What is the likely source; where should I start?
- RickHaleParker
- Been thanked: 958 times
Start with pulling the wheels off one by one and do a good inspection of the Wheels, Tires, Brakes and Suspension.
Kurturbanist
Thanks; I will post the resolution when it’s clear.
- jonesg
- Year and Model: 2004 V70
- Has thanked: 70 times
- Been thanked: 483 times
rotate rear wheels to the front, if it gets worse you might have a distorted rim.Kurturbanist wrote: ↑23 Aug 2020, 19:35 My 2002 v70 XC has gotten really loud at speeds over 40mph. I did drive over a Piece of lumber on the freeway and the left rear wheel seems to be the origin of the noise since then. When I turn more than 15 degrees or coast downhill it will quiet down briefly. The Volvo has 235K miles and rolls on new Pirelli Scorpions. What is the likely source; where should I start?
Imbalance shows up more on the front than the rear of the car.
It might be nothing more than a missing balance weight.
