A/C rumble / vibration after little use.
jonesg
Year and Model: 2004 V70
Has thanked: 69 times
Been thanked: 479 times
Re: A/C rumble / vibration after little use.
Post by jonesg »
BlackBart wrote: 16 Jul 2025, 10:54 3.7, check.
a $10 stethoscope really helps with vibration locating.
Has thanked: 1497 times
Been thanked: 3809 times
Only 3 years here, 3.7 Canadian years
BlackBart
Has thanked: 927 times
Been thanked: 884 times
Post by BlackBart »
I’d better plan ahead then!
We’ve decided to join the masses and run it all the time to loosen it up.
Blacklab467
Year and Model: 2007 xc 70
Has thanked: 113 times
Been thanked: 262 times
Post by Blacklab467 »
I just run mine in AUTO and 20 degrees......year round. That ensures everything keeps moving.
2003 XC 70 (sold)
BlackBart wrote: 19 Jul 2025, 12:56 I’d better plan ahead then!
A bit like a wheel hub. It’s a nice failure because it will worn you before it totally FUBARS
unlike a wheel hub, you can turn it off at that point.
