Timing Belt Sync 2005 Volvo S60 Turbo AWD Topic is solved
jotoya
Year and Model: 1996 850
Has thanked: 6 times
Been thanked: 6 times
Re: Timing Belt Sync 2005 Volvo S60 Turbo AWD
Post by jotoya »
Update:
Incredibly fortunate that no valves were bent. Shop said, "the timing was off by half a turn". Super excited about this. They get'er going.
However, they charged me TWO hours of labor. I gave them the car with everything removed so they wouldn't spend time (and charge me that time) removing covers, bars, bolts, etc. All they had to do was throw the serpentine on and fire up the car.
Are these 2 hours justifiable? He even called me the day before he figured things out to let me know he was expecting a timing tool to arrive. Two hours to figure out that the crank was a half a turn off??
Has thanked: 292 times
Been thanked: 765 times
jotoya wrote: 14 Jul 2025, 21:49 I know there are a kabillion post/videos regarding timing belt installation and whatnot. But it seems that I can never find information specifically for a 2005 S60. All of this to say that I have R&R my timing belt....BUT, I am scared out of my mind to fire up the car because I simply cannot tell where it aligns in the crankshaft. I've viewed the FCPeuro video and that's an 04 S60. What Jay says in the video, it simply does not exist in my 05.
Now, I have turned the motor a few times and then aligned my top cam notches. From there, I turned the crankshaft twice (full rotation I believe) and after those 2 turns, the cam marks align again.
All should be aligned now correct? Any guidance is appreciated.
Many thanks,
Jose
No, this test/observation does not help if I'm interpreting correctly that the issue is with the crank mark, that you don't know whether or not the crank is in the right place.
The cam marks will basically always be in the same place after two revolutions, although you should always check to be sure. But that observation doesn't tell you whether or not the cams are timed properly to the crank.
The solution here is to find the crank (or harmonic balancer) mark, you simply MUST find it and make sure it's in the right place. An 04 S60 is the same as on 05 S60 FWIW, though of course I haven't seen your car to know what you're dealing with.
EDIT: just seeing your most recent update now, after posting.
The shop charge may seem high but they saved your bacon and provided expertise to confirm proper VVT timing, two hours is not bad IMO. A full timing belt job is probably 3-3.5 hours book charge?
'06 S60 R, 197k
'07 XC70, willow green, 212k
'99 Camry V6 :shock: 153k
jotoya
Post by jotoya »
Thanks Eric. So, the repair is done the car is good to go now. I added a follow up question of the 2 hour and if it was justified.
vtl
Year and Model: 2005 XC70
Has thanked: 114 times
Been thanked: 606 times
Post by vtl »
chrism wrote: 17 Jul 2025, 12:37 I’d have to assume that method is for the person that doesn’t want to replace the tensioner and idler or check for play in the water pump. Just a quick and dirty belt replacement.
Timing belt on this engine is about 3 hours of work the first time you do it. Well under 2 hours afterwards.
vtl
Post by vtl »
jotoya wrote: 28 Jul 2025, 14:01 Thanks Eric. So, the repair is done the car is good to go now. I added a follow up question of the 2 hour and if it was justified.
Yes. Let it go.
jotoya
Post by jotoya »
vtl wrote: 29 Jul 2025, 09:31
Yes. Let it go.
Perhaps you're the "let it go" type. I'm not when I perceive something is done unfairly. For anyone else that is annoyed with my question just scroll. Otherwise, I welcome thoughts.
vtl
Post by vtl »
jotoya wrote: 29 Jul 2025, 10:50 Perhaps you're the "let it go" type. I'm not when I perceive something is done unfairly. For anyone else that is annoyed with my question just scroll. Otherwise, I welcome thoughts.
I'm the one who does everything myself. 2 hours is about how long the belt takes me.
jonesg
Year and Model: 2004 V70
Has thanked: 69 times
Been thanked: 481 times
Post by jonesg »
Consider why this forum exists.
It often simmers down to 'I can't afford pro rates.'
jotoya
Post by jotoya »
jonesg wrote: 29 Jul 2025, 13:55 Consider why this forum exists.
I did consider why the forum exists and it was just thoughts to a question I asked. Wasn't looking for folks to jump in my bandwagon but seeking for honest dialogue. I am always more than willing to pay pro rates especially when I know my own limits.
Vova585
Has thanked: 155 times
Been thanked: 142 times
Post by Vova585 »
2 hours is very fair. Guys had to spend time to find proper info about how to set up timming in this car( alldata os around $200 per month for ahop), they had to probably buy special tool which will possibly never will be used again if you dont have much volvos around (so around $45 for Amazon version of the tool), you need to pay tech to do the job, you need owner to make profit to be available to you next time you need them. Be happy car is working and no damage is done. Be thankful to tech to agree to work on it(in my area most of people start to make cross the moment I ask them to work on volvo and refuse as fast as possible). Dealer would charge all 3 hours.
