Permanent removal of rear seat, 2006 Volvo XC70 Topic is solved
Rvolvos
Year and Model: 2006 xc70
Has thanked: 73 times
Been thanked: 23 times
Post by Rvolvos »
Looking into permanent removal of the rear seats, both upper and lower parts. I drive mostly alone and partly in the mountains and have a long commute, always carrying load and have a full size spare in the back.
In short trying to loose some weight from the car. Found a how to video for the removal process. It shows you have to disconnect the SRS connectors from the upper portion. I assume for the seat belt tensioners.
My question is, is there way to prevent the SRS light on the dash coming on?
2006 XC70 2.5T 238k
2012 S60T6 95k rip
2011 C30 T5 M66 105k Totalled RIP
2006 V70 2.5T 184k RIP
2011 C30 T5 AW55-50SN 99k sold
Has thanked: 1505 times
Been thanked: 3818 times
You will have to reconnect the tensioners to the wiring to keep SRS off. Also all that has to be done with the battery disconnected
BlackBart
Has thanked: 927 times
Been thanked: 884 times
Post by BlackBart »
You could also fabricate a wooden shelf / platform that's level with the rear load deck. Unless the rear floor space is handy for you.
vtl
Year and Model: 2005 XC70
Has thanked: 114 times
Been thanked: 606 times
Post by vtl »
Just fold it down? It converts into a perfect flat platform, why even bother with the removal? The seats also take big part in sound dampening.
Year and Model: 2001 V70
Been thanked: 1000 times
Post by volvolugnut »
I have removed my 2001 V70 rear seats for repairs. As I remember, they are very light. Not much weight to be saved, but if you want more room, even folded they take up considerable storage space.
With no passengers besides my wife, my seats is always folded down. The same way I used my 1975 and 1983 245s.
Also, be careful not to start the car with the SRS connectors disconnected. It will set a code that takes a special reader to reset. I know from personal experience.
