Looking into permanent removal of the rear seats, both upper and lower parts. I drive mostly alone and partly in the mountains and have a long commute, always carrying load and have a full size spare in the back.
In short trying to loose some weight from the car. Found a how to video for the removal process. It shows you have to disconnect the SRS connectors from the upper portion. I assume for the seat belt tensioners.
My question is, is there way to prevent the SRS light on the dash coming on?
Permanent removal of rear seat, 2006 Volvo XC70 Topic is solved
Rvolvos
- Year and Model: 2006 xc70
- Has thanked: 73 times
- Been thanked: 23 times
2006 XC70 2.5T 238k
2012 S60T6 95k rip
2011 C30 T5 M66 105k Totalled RIP
2006 V70 2.5T 184k RIP
2011 C30 T5 AW55-50SN 99k sold
2012 S60T6 95k rip
- Has thanked: 1497 times
- Been thanked: 3809 times
You will have to reconnect the tensioners to the wiring to keep SRS off. Also all that has to be done with the battery disconnected
- BlackBart
- Has thanked: 927 times
- Been thanked: 884 times
You could also fabricate a wooden shelf / platform that's level with the rear load deck. Unless the rear floor space is handy for you.
- Been thanked: 999 times
I have removed my 2001 V70 rear seats for repairs. As I remember, they are very light. Not much weight to be saved, but if you want more room, even folded they take up considerable storage space.
With no passengers besides my wife, my seats is always folded down. The same way I used my 1975 and 1983 245s.
Also, be careful not to start the car with the SRS connectors disconnected. It will set a code that takes a special reader to reset. I know from personal experience.
- 2375 Views
Last post by 2008XC70
- 3397 Views
Last post by Blacklab467
