Will '98 850 alternator fit an 02 S60 (both with T5 engines)
850TurboTurtle
Year and Model: 96 850T, 05 S80T6
Has thanked: 10 times
Been thanked: 5 times
Post by 850TurboTurtle »
My wife has a 2002 s60 with a bad alternator (getting a message claiming 'electrical system needs service'). I put a new regulator from IPD on the existing alternator and the same message appears. I have a 98 T5 950 with a blown engine. Will that alternator work as a replacement?
the 850 engine bay and alternator
the s60 engine bay and alternator
Been thanked: 466 times
Post by cn90 »
Check FCPEuro but I believe the alternators between P80 and P2 are not interchangeable.
Also rotation (CW vs CCW) issue too...
850TurboTurtle
photo of the 850 alternator:
IMG_5252 2.jpeg (123.6 KiB) Viewed 270 times
Has thanked: 1836 times
Been thanked: 1709 times
The P80 -98 alternator as cn90 says rotates the wrong way unfortunately. Belt routing is also different.
Has thanked: 1497 times
Been thanked: 3810 times
Mounting bolts amd hardware on the RN block, from 1999- , are completely different too.
Other than spatial, mechanical, and electrical differences, they are identical. The colour is a bit different too.
