Cruise control 2004 volvo v70
tcliffordpont
- Year and Model: 2004 v70 turbo fwd
- Has thanked: 1505 times
- Been thanked: 3818 times
P2 cruise control is all electronic. Are the buttons on the dash sticky? Mine sticks on sometimes and wipes out cruise.
Check your ECU for codes , some of them inhibit cruise. BCM codes will do.
VIDA is the best tool to troubleshoot. Comm problems between CDM and ECU will inhibit cruise
dikidera
- Year and Model: S60 2005
- Has thanked: 68 times
- Been thanked: 175 times
The brake pressure sensor located in the engine bay on the booster itself becomes rusted slightly leading to improper detection when braking. This emits a DTC and inhibits cruise control.
Carefully remove it and try pressing on the switch, if you are hearing the spring inside sound difficult to move or rusted/sqeuaky, spray WD-40 around the switch and press it several times to get it in there.
Fix will work for around a year depending on climate.
Of course your issue could be different, but this is one issue where it inhibits cruise control, apart from the buttons themselves.
- br0dy519
- Year and Model: 2004 XC70
- Has thanked: 126 times
- Been thanked: 116 times
I wouldn't invest too much time in this guys. I smell AI.
04s60 2.4
04xc70 2.5t
04xc70 2.5t
