JB weld plastic repair advice needed
darylrobert
Year and Model: V70 240 740t xc70
Has thanked: 6 times
Been thanked: 42 times
Post by darylrobert »
Attempting to repair my Heater temp control button. Plastic is ABS/PC, purchased an expensive product (made in the USA) JB Weld plastic.
Its been over 15hours and its not drying...will it ever dry? Package says it dries in 1 hour but longer at freezing temps. Its 80F yesterday and today 85% humidity..not freezing. In hindsight i should have tested product on scrap material before on actual repair..you can see from the picture i glues in a metal strip reinforcement which will probably break the whole thing if i try and remove :evil: :evil: lesson learnt
button repair
button repair
Has thanked: 1834 times
Been thanked: 1709 times
It normally set pretty quickly. I have used many variants of JB Weld 2 part glues. I recall one pack where it seemed to take longer to set than others. When I reread the instructions, I had misread it. It said it set in 5 minutes, but fully hardened in 24 hours or something like that.
So unless the hardener has gone bad, or it was mixed sufficiently well, I don't know what to say. I would contact JB Weld noting the product type and ask them what is going on. I have used their plastic repair 2 part many times for P80 dashboard repairs and other plastic items.
jonesg
Year and Model: 2004 V70
Has thanked: 69 times
Been thanked: 479 times
Post by jonesg »
sets quick but takes 24 hrs to cure.
darylrobert
So what i think happened was incorrect mixing ratio. At first the yellow (hardener i think) refused to come out but the clear did. I put the clear aside but being clear and hard to see, i think i accidentally mixed it in. And YES i was wearing my glasses :shock:
When it has been sitting that can happen if you are not aware of it. I have learned the hard way!
