Antoine240bk
Year and Model: XC70 2.5T-2006 - 4C
Has thanked: 12 times
Been thanked: 30 times
Post by Antoine240bk »
Blacklab467 wrote: 19 Oct 2025, 05:17 Wow, beautiful car! Any chance you copied the P/N from the scuff plate before you installed it?
Thanks!
This came as a kit, Aluminium Side Scuff Plate - 30730004
I had chance for sure and most of the clips were unbroken, i fixed three of the eight clips.
Unfortunately I did not took pictures of the P/N inside the side scuff plates.
Volvo XC70 2.5 T AWD P2 B5254T2 - 12/2005 Four-C Previous : Volvo V70 P1 2.4l 20s 170ch B5244S 03/2000 - Volvo 245 GL Break 1979 B21 -LPG - Volvo 240 GL Break 04/1992 B230F (Daily for 14 years)
Has thanked: 1497 times
Been thanked: 3809 times
Dropped my BCM due to an electrical fault causing an evil burningsmell. It’s a Xmodex rebuild so I’ll get a RMA going,hopefully get it shipped before I head to airport
tfo
Year and Model: 2007 XC70
Been thanked: 5 times
Post by tfo »
finally replaced the parking brake hardware (PPS parking brake rebuild kit) + bosch quietcast rotors and pads. left side went well, but right side had a few things of note- the aligning springs that hold the brake shoes flush are holding onto damaged tabs. they havent come off in my use of my (now newly functional) parking brake, and no weird sounds like before on my rusty shoes + rotors.
i was able to fit the new pads just fine in the left side caliper and onto the rotor, but the right side's caliper gave me more trouble. even when i depressed the actuated pad as much as possible, the gap between the pads was not wide enough to get over the rotor. i had to use my old pads (which still had plenty of meat on them, just semi-metallic instead of ceramic). no uneven braking or weird sounds either, and i've been driving on them for about a week now. bedded them and the parking brake shoes according to VIDA.
i have the fronts to do next, (i ran out of daylight working on the rears, and i have very little time between university and work) and they'll be WAY faster to put on than the rears, since there's no drum brake crap on the front wheels, thank god. if 18 years of rust is this bad on an '07, i can't imagine how bad working on a car with drums in all corners from the '70s is.
i also happened to get a lot of brake dust on my partner's clothes, and i was thinking Borax would be best to get the stains out. unfortunately, i already attempted to wash them with hot water, so i might be out of luck-- but I have to try!
she/her
the sea of estrogen in question
PYXIE: 2007 XC70 ~172k mi.
br0dy519
Year and Model: 2004 XC70
Has thanked: 123 times
Been thanked: 115 times
Post by br0dy519 »
tfo wrote: 21 Oct 2025, 10:09 damaged tabs
Same issue on my dust shield backing plates, both of them are damaged, one completely ripped through. Yours was obviously salvageable?
I'm struggling to try and justify actually replacing these dust shields which are a PITA and require removal of the wheel bearing it appears.
04s60 2.4
04xc70 2.5t
tfo
Post by tfo »
yeah, not fully ripped through, but one side was pulled off of the dust shield for both top and bottom tabs. not only are they a PITA to replace, but also 10x more expensive from Volvo than the fronts.
also for my front brake job, i got a brand new front left dust cover replacement for ~$12 on FCP Euro supplied by Volvo, as the one on Pyxie right now is missing a chunk and was making squeaks when i turned to the right. I bent it out of the way by hand the same day i did the rear brake job; a fine temporary fix IMO. i think the rear dust covers are over $110. besides being attached to the hubs and having spring retainer tabs, why is it so much more expensive???
she/her
br0dy519
Post by br0dy519 »
Not sure but there are alternatives. I found PPS versions for around $45CDN on RockAuto.
Shoe delaminating, cables failing, dust shields breaking, and by far my all-time favourite failure: the support block. https://www.skandix.de/en/spare-parts/b ... e/1021835/
I deleted my parking brake years ago and never bothered to fix it (flat area).
04s60 2.4
04xc70 2.5t
Blacklab467
Year and Model: 2007 xc 70
Has thanked: 113 times
Been thanked: 262 times
Post by Blacklab467 »
Installed a spoiler wing on the XC. I found this in an autowrecker for $30 and had to paint it Lava Sand before installation.
2003 XC 70 (sold)
matthew1
Site Admin
Year and Model: 850 T5, 1997
Has thanked: 2650 times
Been thanked: 1240 times
Post by matthew1 »
Looks great ^
Also -> Amazon link
Has thanked: 1834 times
Been thanked: 1709 times
Nice job indeed!
BlackBart
Has thanked: 927 times
Been thanked: 884 times
Post by BlackBart »
I like your organized garage.
