Front door central trim moulding removal 2006 XC 70
Metallo
Year and Model: XC 70 AWD 2.5 - 2006
Has thanked: 7 times
Been thanked: 6 times
Post by Metallo »
Hi folks,
This is an XC70 2006.
The passenger from door got rusty underneath the central plastic trim, so I need to remove the rust and paint it.
How do I remove that plastic trim? To give you an idea, I am talking about P/N 39987405.
I am sure there are plastic clips, but I do not know whether I need to remove the interior panel and push them out or pull from them from outside, which most likely will break them.
Thank you,
Alex
Polar 940 Turbo SW - 1997
Metallo
Post by Metallo »
Hey everyone, today I finally found the time to take a look at removing that plastic trim. After taking off the interior panel, I discovered there was nothing visible from the inside, (no clips) so I went ahead and began ungluing the trim. Piece by piece, I worked my way through it until I reached the end and that’s when I came across an unpleasant surprise:
I am not a welder, so I am asking what is the best way for me to patch that hole?
Perhaps, would it be easier to find a used door at a salvage yard?
Thank you,
Alex
Has thanked: 1836 times
Been thanked: 1709 times
Wow, I have never seen that on a P2, even in a scrap yard no matter what year. That is really un-lucky. Has the car been damaged and repaired previously?
The door could be reskinned and painted, but I'd look out for a used door in color.
Metallo
Post by Metallo »
scot850 wrote: 08 Nov 2025, 17:04 Wow, I have never seen that on a P2, even in a scrap yard no matter what year. That is really un-lucky. Has the car been damaged and repaired previously?
I haven’t seen this before either. The car has never been in an accident, which makes it quite strange considering that the trim is sealed with glue. The only explanation I can think of is condensation inside the door, though that seems a long shot.
I’m already looking for a black door, but it’s not easy to find one in the right color and without scratches.
On Monday, I’ll contact some junkyards in our country to see if they have anything available.
Thank you,
Alex
Blacklab467
Year and Model: 2007 xc 70
Has thanked: 113 times
Been thanked: 262 times
Post by Blacklab467 »
I had a similar rust spot only not as bad on my '03. I got a door in the correct color for $40 at the wreckers and gave it a polish. You can't even buy a can of spray paint and primer for $40 anymore, not to mention the time it would take to repair a hole like that properly. Although NB may find these cars scarce in the auto wreckers, or maybe auto wreckers are scarce in NB also.
2003 XC 70 (sold)
Metallo
Post by Metallo »
Yes, I agree with you all, getting a door from a junkyard seems like the best solution. Here in NB, it’s really hard to find anything for Volvo cars; about 99.99% of the parts I source come from the US since local junkyards rarely get Volvos, which probably comes down to population. I’m also checking Facebook Marketplace and I found one possible match and I’m waiting to hear back. I also looked on car-part.com and saw a few options, but they often don’t list the color, so I’ll have to call tomorrow to ask.
Not sure if Erie Vo-Vo is an option for you down in New York area. Shipping might be a bear.
DavidE7
Year and Model: 01-07 V70, S60, XC70
Has thanked: 53 times
Been thanked: 61 times
Post by DavidE7 »
The P2 XC70 doors are the same as the V70 and S60. The bottom trim on the XC70 is the only difference. The wiring harness changed from the 01-04 P2 versions to the 04-09 P2 versions. Shipping a door would be a big pain.
David E
2001 Moondust V70 2.4 293,000 miles
2001 Nautic Blue V70 2.4 224,000 miles
2004 Nautic Blue XC70 2.5T 251,000 miles
new: 2004 Black Saphire V70R 193,000 miles
2007 Titanium S60 2.5T 275,000 miles
2007 Magic Blue S60 2.5T 233,000 miles
2007 Silver V70 2.4 200,000 miles
P2 Volvos for every person in my family
Metallo
Post by Metallo »
scot850 wrote: 09 Nov 2025, 05:53 Not sure if Erie Vo-Vo is an option for you down in New York area. Shipping might be a bear.
I Neil,
Erie is one of the main suppliers for me, they have nothing on the internet, as far as I have seen, but I can call them tomorrow.
Metallo
Post by Metallo »
DavidE7 wrote: 09 Nov 2025, 06:38 The P2 XC70 doors are the same as the V70 and S60. The bottom trim on the XC70 is the only difference. The wiring harness changed from the 01-04 P2 versions to the 04-09 P2 versions. Shipping a door would be a big pain.
Hi David,
If the wiring harness has changed, I’ll need to double-check that as well. The person I mentioned earlier, from whom I’m still waiting for an answer, has an ’04, so even if the door itself is compatible, I still need to verify the wiring. It’s possible I could swap it with the one from my current door, but first I have to confirm whether that replacement door is actually in good condition.
I also agree that transportation costs are definitely high. On top of that, when importing parts, even used ones, from the U.S. into Canada, you have to pay taxes depending on the province. For example, in New Brunswick it’s an additional 15%, while for our friends in Alberta it’s 5%, and so on. So yes, ideally I’d find a door here in Canada, but if that’s not possible, then the U.S. will have to be my only option.
Thank you,
Alex
