Front door central trim moulding removal 2006 XC 70
Has thanked: 1834 times
Been thanked: 1709 times
Re: Front door central trim moulding removal 2006 XC 70
That is the only advantage of living in Alberta.......... :o :lol: :lol:
Another place worth a try is LKQ. They have a large yard in Quebec as well as linked yards that may still carry older cars.
I got a transmission from them for a 2012 XC60 off the shelf. Appreciate it is a newer model.
Metallo
Year and Model: XC 70 AWD 2.5 - 2006
Has thanked: 7 times
Been thanked: 6 times
Post by Metallo »
Folks,
I found a good used door, from an XC 70 2007, mine is a 2006. The problem is that I cannot align it.
Both doors never had an accident, I tried to switch the hinges, so I put the ones of my old door in the 2007 one, but still no way to align it.
Is there any type of adjustment that I am missing??
Alex
Polar 940 Turbo SW - 1997
Maybe worth PM'ing Blacklab467 on this. I know he replaced doors on his 03 XC70 and had some issues.
DavidE7
Year and Model: 01-07 V70, S60, XC70
Has thanked: 53 times
Been thanked: 61 times
Post by DavidE7 »
Swapping the wiring harness from the old door to the new door isn't exceptionally difficult. There is a series of fir tree fasteners that have to be pulled and then the wiring routed the correct way to reach each of the electronic components: latch/lock mechanism, two speaker plugs, window motor, rear view mirror, and switch assembly. Look at the Volvo part numbers on the tags. If they aren't the same, swap the original harness over to the replacement door. Also make sure you keep the original switch module.
David E
2001 Moondust V70 2.4 293,000 miles
2001 Nautic Blue V70 2.4 224,000 miles
2004 Nautic Blue XC70 2.5T 251,000 miles
new: 2004 Black Saphire V70R 193,000 miles
2007 Titanium S60 2.5T 275,000 miles
2007 Magic Blue S60 2.5T 233,000 miles
2007 Silver V70 2.4 200,000 miles
P2 Volvos for every person in my family
chrism
Year and Model: S80 / 2005
Been thanked: 78 times
Post by chrism »
Is there no way to move the upper hinge forward where it bolts to the body?
chrism
Post by chrism »
Oooops…. Duplicate post.
