Front Seat Bolt Cover Removal V70, 2004
BobbyC777
Year and Model: V70 2.5T, 2004
Has thanked: 15 times
Been thanked: 5 times
Post by BobbyC777 »
Gang -
One of these days I'll try to fix the driver's seat heating issue. The first obstacle is removing the plastic covers that cover the front bolts that attach the seat to the tracks. Breaking them would be a bad way to start. The tips I've seen all seem to relate to a cover that looks different than mine.
The replacements I see on the IPD website (9199829) don't have the little hump that goes over the main screw mechanism inside the track.
Any tips on removal would be appreciated. Thanks!
Been thanked: 466 times
Post by cn90 »
I think the plastic piece slides forward.
BobbyC777
Post by BobbyC777 »
IPD suggested that the correct part # is 39975895
I think they are correct from the image I found:
https://www.getoemparts.com/oem-parts/v ... wtbDUtZ2Fz
I will take @CN90's suggestion and try to slide it forward again). It sure feels tight.
The part is not longer available so I really don't want to break it.
Post by cn90 »
When in doubt, check eBay used stuffs.
Searching eBay for the PN, found the photo!
So pry the front part of the cover upward....
BobbyC777
Post by BobbyC777 »
Thanks, cn90 ! I actually did search eBay for the part # earlier but no luck. Not sure what I was doing wrong. That sure looks like the part and prying from the front should do it. I may wait for a warmer day just so the plasic isn't quite so brittle.
Has thanked: 1497 times
Been thanked: 3810 times
I little bit of down ward pressure against the carpet helps remove these, I think maybe use the eBay pictures to visualize the connectors /
matthew1
Site Admin
Year and Model: 850 T5, 1997
Has thanked: 2650 times
Been thanked: 1240 times
Post by matthew1 »
BobbyC777 wrote: 16 Dec 2025, 17:57 I may wait for a warmer day just so the plasic isn't quite so brittle.
Exactly what I would do. Or heat it gradually, not with a torch or heat gun but by blasting heater to floor for 20 minutes while I drive, windows down. Or even a "Bed Buddy" https://amzn.to/4pFyOGn - don't laugh, I use mine to heat ink to print MVS t-shirts because my rig is in the cold basement.
Also -> Amazon link
BobbyC777
Post by BobbyC777 »
SUCCESS - well, so far.
I started with left cover of driver's seat. I pushed down on the carpet at the front of the cover which provided a little room. I put a medium sized flat blade screwdriver in under the cover from the front (left of center) and pried & prayed and it popped off. When I do the other one i will probably use two screwdrivers to equalize the pressure.
arrow points to bracket over which plastic cover attaches
underside of cover showing slot
Part # for this cover is 8674694
Thanks, cn90, abscate, Matt !
BobbyC777
Post by BobbyC777 »
I wanted to document how to remove the bolts covers from the rear of the front seats. It's not rocket science but getting those covers off is normally the first thing one does when removing the seat and starting off by breaking them is a difficult way to begin.
The rear plastic covers are a press fit onto a metal bracket which angles back and up at a 45* angle. So pulling back and up is how to do it. I used the curved end of a Wonder Bar® to accomplish this. It has the added benefit of distributing the force over a wide area which may help to keep the cover in tact.
The next picture shows the bracket over which a rectangular box fits. The pencil is used to push down the carpet in order to see more of this metal bracket. The small white area on the bracket is the flash reflection of a little 'bump' which ends up helping to hold the cover in place after the cover slides onto this bracket.
The next picture shows the underside of the cover with the molded rectangular slot that fits over the metal bracket and snaps into place.
For my US Volvo
The part # of the driver side left rear cover is: 8674695
The part # of the driver side right rear cover is: 8674696
Good luck !
BobbyC777 wrote: 17 Dec 2025, 15:14 SUCCESS - well, so far.
Thanks to you for a great set of clear pictures, worth 3000 words!
There is a warm place in Heaven for posters who reference part numbers…
For my US Volvo
