9400 Code !
AlanS
Year and Model:
9400 Code !
Post by AlanS »
2006 XC70 Im still trying to sort this code out. Went to my local mechanic to see if his reader is any different than mine. Both came up with 9400= Accelerator Pedal Sensor. Symptoms: When I start the car, the dash reads "Reduced Engine Performance". Shut it off...start again, dash message gone. Hook up reader- 9400. That part is expensive. FCP shows that it is included in a new pedal, not separate. Is there a way (without VIDA- no one I know has VIDA here on Long Island) to determine if I REALLY need the Pedal Sensor before spending $250?
dikidera
Year and Model: S60 2005
Has thanked: 67 times
Been thanked: 175 times
Post by dikidera »
I also get the ECM-9400 code on my NA engine, but it is the Brake Pedal Position sensor, not the Accelerator, you sure you read it correctly?. Mine started when I had initially removed the brake sensor in the driver side pedal area, due to a burst heater core matrix. Since then, the code would often trip and I lose Cruise Control. Yet the sensor online is the one on the brake booster outside?
xanthefin
Year and Model: 1997 850
Has thanked: 106 times
Been thanked: 130 times
Post by xanthefin »
ECM-9400 is Accelerator Pedal position sensor fault code on ME7.01 systems example of B5254T2 after 2005 years.
Has thanked: 1497 times
Been thanked: 3810 times
Check fuses and wiring before spending on the sensor. They almost never go bad.
AlanS
Year and Model:
Post by AlanS »
How do you ‘check the wiring’?
Make and break the connector on the pedal sensor first, fancy words for remove and replace. You are trying to clean all the electrical pins inside the connector.
You can also order it from FCP and carefully open the box with a razor to test a new part. FCP will take back electrical stuff unlike most. Maybe confirm with them first, too.
Anth9998
Year and Model: 2006 xc90
Post by Anth9998 »
Did you ever figure out what was causing this? I am having the exact same issue in my 06 xc90. 2.5t. Any info you could provide would be appreciated.
