I found this turbo vacuum line disconnected
jw113
Year and Model: 2007 V70 2.5T
Has thanked: 3 times
Post by jw113 »
While replacing the crank position sensor (CPS) today I noticed a disconnected vacuum (?) line at the air inlet tube nearest the turbo inlet.
Here's before I reconnected it:
Turbo Line 1.jpg (59.18 KiB) Viewed 108 times
and here's after:
Turbo Line 2.jpg (68.24 KiB) Viewed 108 times
I found a vacuum line diagram online that suggests this is the "blue" line, but does anyone know what it does?
I've had the car 12 years and no one has done any work in that area, so who knows how long it's been disconnected. The car ran fine without it connected.
Thanks for any info.
2007 V70 2.5T
Has thanked: 1505 times
Been thanked: 3818 times
The blue line returns the pressure that isn’t used by the turbo control valve back to the snorkel so no boost pressure is “lost”
If to pops off , the turbo will work fine but you may get a lean code for a vacuum leak if you have a light foot
DavidE7
Year and Model: 01-07 V70, S60, XC70
Has thanked: 53 times
Been thanked: 62 times
Post by DavidE7 »
The port for the hose that popped off doesn't have a barb or other retaining feature. It appears that the only way it is retained is with friction and the partial vacuum from the engine and turbo intake through the venturi (diameter reduction) on the intake pipe. A little spring clamp would probably be smart.
The larger hose above it for the carbon canister fuel vapor purge has a small barb on the port . On my three turbo charged vehicles, I found that plastic clip for holding the O2 sensor wire clipped to hold the hose from pulling off the barb. You may want to slide that clip downward to help retain that hose on its port.
I have chased enough false air faults with smoke that I think my cars will each get a spring clamp like the ones at the Turbo Control Valve on that small hose.
David E
2001 Moondust V70 2.4 293,000 miles
2001 Nautic Blue V70 2.4 224,000 miles
2004 Nautic Blue XC70 2.5T 251,000 miles
new: 2004 Black Saphire V70R 193,000 miles
2007 Titanium S60 2.5T 275,000 miles
2007 Magic Blue S60 2.5T 233,000 miles
2007 Silver V70 2.4 200,000 miles
P2 Volvos for every person in my family
vtl
Year and Model: 2005 XC70
Has thanked: 114 times
Been thanked: 606 times
Post by vtl »
Light foot definitely, since TCV only triggers in high engine loads, when it needs to get rid of of boost quickly. Vacuum leak was probably minimal, fuel trim idn't migrate to out of range yet.
