98 V70 AWD found broken vacuum line.
PooYork
Year and Model: 2011 Volvo V50
Post by PooYork »
i was replacing my ABS module today and I found a broken vacuum hose. It's a yellow hose that hooks into the top right port of the Turbo Air Intake Hose.
Here is the link to the part
http://www.ipdusa.com/products/7159/114 ... 70-s70-v70
My question is, where does this line go? I couldn't for the life of me find the break and i traced many lines as well as looked at a diagram of vacuum lines to no avail.
Thank all you MVS'ers.
1993 Volvo 940SE 200,000
1998 Volvo V70 118,000
2000 Volvo V70 126,000
1998 Volvo V70 AWD 155,000
2011 Volvo V70 110,000
Acknar
Year and Model: 940, 1993
Post by Acknar »
That line should be marked blue and is the fresh air line from the turbo control valve (TCV). The yellow marked line should go to the waste gate. The TCV should be mounted on the airbox near the bottom of the passenger side.
http://ww2.justanswer.com/uploads/JC/jc ... iagram.jpg
Scholz
Year and Model: 1998 S70T-5
Post by Scholz »
I had a similar moment of panic when I bought my car. I ended up finding the component mentioned above resting on the oxygen sensor harnesses directly below the airbox to turbo hose that your vacuum line is hanging from.
It's a small module with three vacuum nipples and an electrical dongle. Two go to the turbo and the yellow one to the pipe as mentioned above.
PooYork
Post by PooYork »
see the strange part here is that i checked both of those places and all lines are intact. i have a phantom hose here.
Clockboy
Year and Model: 05 xc70, v70 2.5t 06
Has thanked: 2 times
Post by Clockboy »
What size hose is it and which port are you talking about?
Year and Model: 2004 V70 2.5T
Been thanked: 504 times
Post by cn90 »
I documented the vacuum diagram as below:
https://www.matthewsvolvosite.com/forums ... hp?t=63615
