I found out where the clunk is coming from.
This video was taken while a helper cycled the shifter, looping through (Drive, Neutral, Reverse, Neutral, ...)
What's wrong in this picture? 06 S60 R
- Has thanked: 292 times
- Been thanked: 765 times
'06 S60 R, 197k
'07 XC70, willow green, 212k
'99 Camry V6
153k
'06 S60 R, 197k
'99 Camry V6
- Has thanked: 1497 times
- Been thanked: 3810 times
I opine that the spline are headed for the Devine…
If the spline wearing is not on the bearing I'll be swearing.
I replaced the CV axle 8 months ago with a GKN (rebuilt). Hub bearings still all original on this car.
'06 S60 R, 197k
'99 Camry V6
153k
'06 S60 R, 197k
'99 Camry V6
Get a new hub , join the failed bearing club, and head to the pub.
- Has thanked: 1836 times
- Been thanked: 1709 times
Why is the axle not turning? Even if the hub has stripped out I'd have thought the inner end and the whole axle would be spinning, but the hub not turning if the wheel hub splines were shot. Are you sure the inner end of the axle has not pulled out from the trans?
Video was taken with the car parked and foot on the brake.
The car drives well, just has a clunk from front left when loading/unloading the drivetrain. Axle fully seated in the trans. Axle nut is tight and doesn't move with the clunks.
The idea is splines are bad enough to slip the small bit, but not fully stripped. Alternatively, the bearing is just wobbling but I'd expect to feel that on the road. Won't really know until I open it up, which may be not for a bit ...
'06 S60 R, 197k
'99 Camry V6
153k
'06 S60 R, 197k
'99 Camry V6
Georgeandkira
- Year and Model: '07 V70 + '15 XC70
- Has thanked: 64 times
- Been thanked: 69 times
delete
- Krons
- Has thanked: 193 times
- Been thanked: 202 times
If I recall right I did my 02 S60 without too much trouble. Just fit with a thinn’ish wall socket and didn’t have to dismantle the whole front suspension.
08 C702.5T (sold)
The non-Swedes:
08 C702.5T (sold)
The non-Swedes:
- 1735 Views
Last post by BollWeevil
- 690 Views
Last post by oragex
