My father always strongly advocated for PB over break cleanser, so here it is. + other fun and highly important stuff. Thank you, Abscate & cn90.
I truly appreciate the knowledge! However, there is no parking hardware currently on this side. Upon removal, the cable shortened up. I have new hardware I’d love to install. Alas…DavidE7 wrote: 14 Sep 2026, 11:30 Did you check to verufy the parking brake isn't sticking? I have had three stuck cables and two rusted expander mechanisms so far this year (mostly from a V70R that had been parked for 5 years). If the disk rotor won't slide off the parking brake pads nice and easy with the brake lever released, something is sticking. I have a person pull the lever while I watch the drum pads expand to see where the sticking is happening. Either the pivot on the expander is binding from rust or the cable is rusting and binding on the inside of the cable housing. Several years ago I had problems with the frinction material detaching from the brake pads.
Years ago now I was headed to an event. Getting off Whitehurst Freeway outside Georgetown, my [“brand new” 2001 XC’s] parking break exploded inside the rotor. That was a fun freeway removal, diagnosis, & rush hour drive/reverse experience outside Exxon.
This experience actually may have been my first post on this forum. Hah!
Suffice to say that if anything fishy [a magically shortened cable] happens with my e-brake, I will sooner zip tie that loose line to the rear control arm than attach finicky hardware.
Anyway, I’m so sore. I’ll be back tomorrow evening for a spit.
Thank you again, my gents. Here’s a nearly candid Freya!
and why not a sleepy Billy Murr woken up
from a nap yesterday.
