Volvo ODBII Codes non-generic
velorider
Year and Model: 2005 S60 T5
Has thanked: 2 times
Been thanked: 27 times
Post by velorider »
I found this over on mp3car.com forum. I thought it might be useful.
Source: http://www.mp3car.com/vbulletin/softwar ... akers.html
[P1014]
CMP Sensor/CKP Sensor Signals Not Compatible
[P1101]
Power Stage Group A Malfunction
[P1102]
Power Stage Group B
[P1103]
Intake Manifold Air Flow Adaptation Upper Limit Achieved
[P1106]
MAP Sensor Performance Problem Or Signal Out Of Range
[P1107]
MAP Sensor Signal Too Low
[P1108]
MAP Sensor Signal Too High
[P1111]
Ambient Air Temp
[P1112]
Ambient Air Temp
[P1113]
Ambient Air Temp
[P1115]
BARO Sensor Performance Problem Or Signal Out Of Range
[P1116]
BARO Sensor Signal Too Low
[P1116]
[P1118]
MAP Sensor/MAF Sensor Adaptation Performance Problem Or Signal Out Of Range (Lower Limit)
[P1119]
MAP Sensor/MAF Sensor Adaptation Performance Problem Or Signal Out Of Range (Upper Limit)
[P1129]
HO2S Electrical Malfunction
[P1131]
HO2S 1 Bank 1 Signal Malfunction
[P1132]
O2 Sensor Front, Bank 1
[P1133]
[P1134]
[P1139]
O2 Sensor Rear, Bank 1
[P1140]
[P1151]
HO2S 1 Bank 2 Signal Malfunction
[P1152]
O2 Sensor Front, Bank 2
[P1153]
[P1154]
[P1159]
O2 Sensor Signal Ageing
[P1160]
[P1169]
HO2S 1 Bank 1 Loss Of Signal
[P1169]
[P1171]
Fuel Adaption, Bank 1
[P1172]
[P1174]
[P1175]
[P1177]
[P1178]
[P1179]
[P1181]
Fuel Adaption, Bank 2
[P1182]
[P1184]
[P1185]
[P1187]
[P1188]
[P1189]
[P1234]
Turbocharger Boost Pressure Sensor Boost Control Malfunction
[P1236]
Turbocharger Wastegate Regulating Valve Inlet Pressure Too Low
[P1237]
Turbo Control Valve
[P1238]
Turbo Control Valve
[P1238]
Turbo Control Valve
[P1241]
Engine Boost Condition Signal Too High
[P1273]
ETS Performance Problem Or Signal Out Of Range
[P1281]
[P1285]
ETS Throttle Valve Adaptation Performance Problem Or Signal Out Of Range
[P1286]
ETS Throttle Valve Adaptation Cancelled
[P1287]
[P1293]
ETS Throttle Valve Adaptation Repeated
[P1307]
Acceleration Sensor, Signal
[P1308]
[P1310]
Misfire from at least 1 Cylunder - TWC Damage
[P1325]
Knock Sensors
[P1326]
Fault in ECM, KS Control Circuit
[P1327]
Fault in ECM, Knock Control Circuit
[P1328]
[P1329]
[P1330]
CVVT Solenoid
[P1332]
CVVT Solenoid
[P1336]
CKP Sensor Signal Not Correct
[P1350]
Ignition Coil 1 primary
[P1351]
[P1352]
Ignition Coil 2 primary
[P1353]
[P1354]
Ignition Coil 3 primary
[P1355]
[P1356]
Ignition Coil 4 primary
[P1357]
[P1358]
Ignition Coil 5 primary
[P1359]
[P1360]
Ignition Coil 6 primary
[P1361]
[P1401]
Fault in ECM, ECT Sensor Circuit's NTC - Connection
[P1403]
Fault in ECM, ECM Box's Temp. Sensor
[P1404]
[P1405]
Temperature Warning Level 2
[P1406]
Termperature Warning > 100 degrees C
[P1416]
EGR Temperature Sensor Signal
[P1417]
[P1418]
[P1440]
Fuel Cap Missing
[P1446]
Fuel System Leak Detection Pump Electrical Malfunction
[P1449]
Fuel System Leak Detection Pump Signal Malfunction
[P1457]
Evaporative Emission System Leak (Fuel Cap Is Loose Or Missing)
[P1460]
Fuel Level Sensor B Electrical Malfunction
[P1480]
PWM fan control
[P1481]
Fan relay 1/2 speed / PWM
[P1482]
[P1483]
A/C Condenser Blower Motor Relay Electrical Malfunction
[P1486]
Fan relay 1/1 speed
[P1487]
Fan relay 1/1 speed
[P1500]
CAN Data Bus ABS Loss Of Signal
[P1501]
MAP Sensor Signal Incorrect During Deceleration
[P1505]
IAC Valve Opening Signal
[P1506]
[P1507]
IAC Valve Closing Signal
[P1508]
[P1513]
Brake pos sensor
[P1520]
APP Sensor Signal Not Plausible
[P1525]
Brake Pedal Position (BPP) Switch Performance Problem Or Signal Out Of Range
[P1526]
ECM Malfunction
[P1528]
Cruise Control Plausibility Performance Problem Or Signal Out Of Range
[P1550]
ABS Wheel Speed Sensor Malfunction (Left Or Right Front)
[P1551]
[P1554]
Engine Control Relay Signal Malfunction
[P1555]
[P1560]
Cruise Control Master Switch Electrical Malfunction
[P1561]
Cruise Control Master Switch Signal Too Low
[P1561]
[P1600]
ETS Malfunction
[P1601]
ETS Throttle Motor Electrical Malfunction
[P1602]
Ignition Discharge Module (IDM) Group B
[P1603]
[P1604]
Ignition Discharge Module (IDM) Group D
[P1605]
Ignition Discharge Module (IDM) Group E
[P1606]
CAN Data Bus ETS Performance Problem Or Signal Out Of Range
[P1607]
ETS Supply Voltage Error
[P1608]
ETS Throttle Valve Command/Actual Throttle Valve Position Correlation Error
[P1609]
[P1610]
[P1611]
CAN Data Bus ETS Update Signals Absent
[P1612]
ETS Loss Of Signal
[P1613]
ETS Malfunction
[P1614]
ETS Throttle Angle Not Plausible
[P1615]
ECM Malfunction
[P1617]
Fault in Lead Between AW 50-52 and Motronic 4.3 (MIL Requested)
[P1618]
[P1619]
Engine Cooling Fan (FC) Low-Speed Signal
[P1620]
[P1622]
Knock Control Malfunction
[P1623]
ECM HO2S 1 Electrical Malfunction
[P1625]
MIL lamp output
[P1626]
MIL lamp output
[P1627]
Serial Communication Link (CAN)
[P1628]
[P1629]
[P1630]
CAN bus node global std code
[P1631]
TCM node
[P1632]
RTC
[P1633]
Vehicle speed signal
[P1635]
ECM internal temp sensor
[P1636]
[P1637]
ECM internal temp high temp level 1
[P1638]
[P1640]
Interlock, powerstage
[P1641]
[P1642]
[P1646]
A/C relay control
[P1647]
A/C relay control
[P1649]
CVVT Solenoid
[P1650]
CVVT Solenoid
[P1651]
Maximum Torque Exceeded Fuel Cut-Off Triggered
[P1652]
Safety Fuel Cut-off
[P1655]
CVVT Solenoid
[P1656]
CVVT Solenoid
[P1657]
ETS MIL Request OFF Signal Low (MIL ON)
[P1658]
ETS MIL Request ON Signal High (MIL OFF)
[P1658]
[P1660]
Cruise Control Lever & Logic
[P1661]
[P1662]
[P1663]
[P1670]
Immobilizer Control Module Communication Error/Code Error
[P1671]
CMP Actuator Performance Problem Or Signal Out Of Range
[P1672]
+5V power supply
[P1673]
+5V power supply
[P1680]
Immobilizer request
[P1721]
Module Cooling Fan Low Constantly Low Signal Or Loss Of Signal
[P1722]
Module Cooling Fan Signal High Or On Continuously
[P1723]
Module Cooling Fan Loss Of Signal
[P1729]
TP Sensor Signal Between Circuit 1 And Circuit 2 No Plausible
[P1738]
HO2S 2 Bank 1 Signal Too Low
[P1740]
EVAP Leak Detection Pump Loss Of Signal
[P1741]
EVAP Leak Detection Pump Signal Too Low
[P1742]
EVAP Leak Detection Pump Signal Too High
[P1770]
CMP Sensor Intake/Exhaust Signal Error
